How do you know it's time to get a new airbox?
Discussion in 'XJ Technical Chat' started by Marko, Aug 2, 2008.
  1. Marko
    Marko Member
    Upstate, NY USA
    Aloha,
    I had a stuck carb float and had to remove them. I figured since I was removing them, I will replace the airbox as well. Yanking it and putting the new one in is for tomorrow, however, I'd thought I'd post a picture or two of the airbox that's been in there now. No wonder I've been having problems. Also, got muffin-"tins" for the carb cleaning. Thought some might dig them.
  2. spinalator
    spinalator Member
    Regina, CANADA
    It looks as though the last pics are in the bedroom. I never clean carbs there anymore.
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If its broke replace it!!
  4. Marko
    Marko Member
    Upstate, NY USA
    Actually the last ones are on the couch. There is a quilt on there because my sister has been sick.
    And thanks to Danno, I've got the replacement ready to install.
  5. RickCoMatic
    I love those Muffin Bins you have there!
    I hope you'll be able to shoot some Carb Cleaner in the bins without damaging the material.
    Looks like somebody did a number on your airbox.
    It can be fixed if you are inclined to do so.
    You'll have to go to an AutoBody Supply Outlet or Harbor Freight and get a Plastic Welding Kit.
    It takes a few minutes to get the hang of filling-in a crack or larger space with the Plastic Rods ... but, after you seal it all up, you can grind and sand it to look like new.
    http://www.harborfreight.com/cpi/ctaf/D ... mber=41592
  6. wizard
    replacement sister?
  7. Marko
    Marko Member
    Upstate, NY USA
    "replacement sister?"
    Heh, no. Sometimes I wish. I mean a replacement airbox.
    The muffin tins are some kind of silicone. They seem to not be affected much, but they were only like $1 each, so I'm not too worried.
  8. acergremlin
    acergremlin Member
    NE UK
    Looks like the air intake boots have shrunk with age and somebody forced the top forward to make them fit again.
  9. RickCoMatic
    Where do you go to buy those Muffin Pans?
    I'll take two!
    Perfect for Carb work!
