How much RPM does youre bikes start up at?
Discussion in 'Hangout Lounge' started by mrhuba, May 13, 2011.
  1. mrhuba
    mrhuba New Member
    Fullerton
    Id like to know the normal RPM rate of when you guys start up youre bike for a warm up?
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    1982 XJ650R - as close to 1100RPMs as I can get it with a factory tach
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I let her run with choke at 2k, and feather off the choke as it creeps up to keep it at 2k.
    I turn the choke off when i'm on the road with no stops ahead of me.
  4. macros10
    macros10 Member
    Newport News, Virginia
    With full choke, cold bike, mine normally idles at around 2-2.5k rpm. Once it starts to warm up, it will jump up into the 3's and 4's and then I go to about 3/4 choke which idles the bike at about 1500 rpms. A minute or so of that and I can take the choke off and it will idle at about 11-1200 and away I go, lol.
  5. ken007
    ken007 Member
    Brisbane, Australia
    i only pull out the choke about a 1/4,it starts imediately and turn of choke straight away , then i rev it too about 1500 rpm for about a minute,it settles on about a thousand once i let go of the throttle,put my jacket and helmet/gear on then take off, i dont go over 3 or 4000 for the 1st few minutes unless i need to get out of the way of a car. having said that the bike isnt outside and it doesnt get cold hear like you blokes get.
  6. cutlass79500
    lawrenceville georgia
    I start mine and back off on the choke to keep it 2k-2500 i just don't like mine revving any higher with no load
  7. BillB
    BillB Active Member
    Tulsa Oklahoma
    no choke... blip blip the throttle and keep it idling around 1300 for a minute and go.
  8. BlkMage
    BlkMage Member
    Stead, NV
    It's still cold here (might have snow this weekend) so mine needs a LOT of choke. Start it full choke, start it a few more times after it dies from the cold, back it out of my driveway, cruise a couple miles down to the freeway, then remove the choke once I get on the freeway. While I back out it may spend some time "idling" at almost 4k, but it kinda needs it on the cold mornings.
  9. autosdafe
    autosdafe Member
    Lorain OH
    Mine starts cold about 2k with the choke and warmed up runs about 1200.
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Must be nice Bill lol
  11. maverickbr77
    maverickbr77 Member
    Lowville, New York
    my normal starting routine. Half to three quarters choke push the button then lower the choke till its about 2000 rpm. Start putting on my gear untill the revs start to pick up then pop the choke down so its at 1500. Finish putting on gear. take the choke the rest of the way off and go. Also my bike idles about a needle width above 1000 when warm.
  12. doc2029
    doc2029 Member
    Richmond, Va
    My 82 XJ650 J like to run about 2K on full choke. Normally I start the bike and let it run while I get my jacket, helmet and gloves on. I leave the choke on until I get on the actual road. I live in a townhouse apt. I keep the bike in the back of my joint and ride it from the front to the back. Usually by the time I get to the parking lot again (5-8 min) total time. I can turn the choke off and it will idle 1,200 -1,500 though hard to really tell with the factory analog tac.
  13. Erman
    Erman Member
    Oslo, Norway
    Full choke, 2-2,5k
    Warm, 1k
    (I do adjust the idle screw often at lights)
