How similar Yamaha XS1100 engine/frame area to 82 Maxim 750?
Discussion in 'XJ Technical Chat' started by Metal_Bob, Nov 2, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    How similar is the from of the Yamaha XS1100 engine/frame area to 82 Maxim 750?
    I ask because I'm currently looking around for lowers for a fairing.
    Basically is the engine about the same width (left to right) and is the valve cover and header pipes in the same general spot?
  2. tcoop
    tcoop Active Member
    South Weber, Utah
    The XS1100 head is a couple of inches wider that the XJ750. So everything is a little different. I could give you exact differences when I get home from work.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The 1100 engine is wider and taller
    MN
  4. Metal_Bob
    Bourbonnais, IL
    So from a LOWERS point of view that would be a good thing. If I got compatable xs1100 lowers they should easily NOT hit the 750 engine :)
  5. MN-Maxims
    Saint Paul, MN
    Yes you are correct.
    MN
  6. bigfitz52
    Just asking, I have no basis to know one way or the other...
    Since the 1100 is wider and taller, aren't the frames different enough that there might be mounting-point issues? I know for instance if you try to use 650/750 case guards on a 550 they will go on but end up at the wrong angles and look goofy.
  7. MN-Maxims
    Saint Paul, MN
    The 1100 frame is wider in the front to except the bigger engine. The Vetter fairing that Metal Bob has will fit almost any of these bikes (Universal fit with different brackets and such). The lower fairings he has found are plastic and have cut outs larger to go around a larger engine. They should fit his bike but have more clearance than the 750 ones he is really looking for. Most people would never notice.
  8. Metal_Bob
    Bourbonnais, IL
    BINGO.
    Well almost. I don't actually have XS1100 lowers yet, but I was looking at some on eBay.
    The ones I do have are less than an inch clearance from the valve cover and 1 & 4 Header pipe (where they are closest to the frame and front of engine). I will probably trim/shape those unless I find some XS1100 cheap enough.
  9. Dylan Miles
    Dylan Miles New Member
    Orem utah
    So can you put
    the xs1100 motor in a xj750 frame
  10. Jerrod Robinson1086
    Jerrod Robinson1086 Member
    Marion Ohio
    I mean with the appropriate funds and ability You could get a Small Block Chevy in there if that's what You really wanted to do. But I seriously doubt the 1100 is going to just line right up with the 750 Mounts.. However, I have been led to believe that a 900 will. Which in My opinion would probably be the better Choice anyway..
  11. Jerrod Robinson1086
    Marion Ohio
    Oh and to be Clear, in no way am I encouraging You to LS swap Your XJ-750. I'm just saying if there's a Will most of the Time there's a way .
  12. k-moe
    Check the...
    13 year-old dead-thread.
