How the hell do you tune a carburetor!!!
Discussion in 'XJ Technical Chat' started by MrSeca, Oct 31, 2020.
  1. MrSeca
    MrSeca Active Member
    Oakland, CA
    I just don't get it guys. I started at 2.5 turns out on the mixture screw. Made sure the carbs were balanced. Then I put on that frickin' colortune that everyone raves about and I really didn't see any difference from when I had the carbs at 2.5 turns out to 5. It wasn't until the mixture screw was practically unseated that I started to see an orange flame. So then I thought, I'll go old school and use my ear. Nope. Nothing. I didn't see a change in idle as I turned the mixture screws out or anything. What the #$%. Can anybody offer some sort of guidance because this just doesn't make any sense.
  2. hogfiddles
    Sounds like you got an air leak somewhere. Just out of curiosity, though, are you sure you have the air jets in the correct places?
    k-moe and Franz like this.
  3. MrSeca
    Oakland, CA
    These are carbs for an xj900. After going through the carbs it's impossible to mix match jets because they can only screw into their respective places but to answer your question everything is in the right spot.
  4. JCH
    JCH Active Member
    seattle wash
    Same here...
    Color tune doe's not work for me too and have tested and reinspected just about everything you can think of, just stays blue all of the time, if you had a vacuum leak I would suspect it would be a white color but check anyway.
    There are other people with the same experience out there.
    There are dyno places for motor cycles out there that will set the CO for you for about 100 bucks or so.
  5. k-moe
    It helps if you use th colortune in a fairly dark place. Makes it easier to read the color.
    If there is no color change then there is still work to do in the carbs, or there is an air leak somewhere.
    Were the fuel levels set using the wet method?
  6. MrSeca
    Oakland, CA
    How would I find a place that does that.
  7. MrSeca
    Oakland, CA
    Yes, everything is in check but to your credit, I did check it during the day and it was hard to see. I'm thinking next time I'll throw a blanket over my head to make it dark or I'll just do it at night.
  8. MrSeca
    Oakland, CA
    You'd think at this day in age someone would've invented a portable oxygen sensor that you could insert into those holes at the bottom of the headers. Is there something like that out there?
  9. JBurch
    JBurch Active Member
    Owego, NY
    You could go REAL old school and do it the way Smokey Yunick did it: dark room, holes in the header tubes about 1 1/2 inch from the flange to see the color of the exhaust gas at the port and he would also read the color of the header tubes themselves.
    You could also use a thermal couple and do it by temperature
  10. hogfiddles
    Our factory head pipes are double-wall, so you won’t really see the color of the pipes too well
  11. JBurch
    Owego, NY
    Well that is one idea down the toilet; try a thermal couple
  12. MrSeca
    Oakland, CA
    I'm a little curious about using O2 Sensors for tuning carbs. I know nothing about them except that you have this sensor thing that is positioned so that the exhaust runs over it and gives you a reading of some sort. Could you possibly use it on an inline four by removing the exhaust except the headers and then just placing the sensor thing into the bottom of each header? I know the bike would be a little loud while you use it but it should feasibly work, right. After all, at the base of the headers there are holes for the 02 sensors to connect to anyway. Why not just put the sensor into the pipe itself and start balancing? thoughts
  13. JCH
    JCH Active Member
    seattle wash
    I would think that in Oakland there would be a lot of places, Two Wheel Dyno Motorcycle Tune Shops ask them if they have the sniffer probes that screw into the exhaust headers if your bike has them ? then they can check the fuel mixture on each cylinder, if not they can still do a CO test, they just do two cylinders at a time if you have two into one exhaust.
  14. JCH
    JCH Active Member
    seattle wash
    Color Tune
    Doe's not work on my bike reads blue all the time.
    Recheck Valves
    Propane test with extended hose to tank, did test twice
    New Pilot and Main jets
    Wet Sync Floats Three times all within 1 mm of spec
    Did test in total darkness with Throttle plate sync tool attached at same time
    Had a Older Yamaha Tech who worked on them back in the day look at it and he said my bike runs better then they did off the showroom floor because they ran so... lean back then
  15. MrSeca
    Oakland, CA
    I actually live in Los Angeles but Oakland is my hometown.
  16. k-moe
  17. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    If you don't see a change in idle or colortune when turning the mixture screws, it means that cylinder is not running on fully on the pilot circuit. That screw adjusts the pilot air circuit, so either it is clogged or being bypassed.
    Bypassed you say? Yes. Let's say it's clogged. Then your butterflies will have to open a little bit further to get enough fuel to idle. Then making adjustments to the pilot air circuit will have not effect.
    If there's an air leak, again, you are bypassing the pilot air mixture, fully opening it will not put enough fuel into the engine to idle and the butterflies will have to open further. If the gasket to the colortune doesn't seal, it'll have a similar effect (and also reduces compression). Have you checked the compression of the engine?
    A final way that you can bypass the idle circuit is by having the carbs be un-balanced. Just because the cylinders pull an even vacuum does not mean they're "balanced." If one butterfly is more closed, it can still pull a vacuum if helped by another cylinder getting more fuel/air, i.e. not being on the pilot circuit, but slightly past it. Intake vacuum is a function of both the restriction (butterfly valves) and the cylinder that is going through its power stroke at the same time as the intake you are measuring. You have to check each of the cylinders with the colortune.
    If all of the pilot circuit passages are clear, then you may find one that actually affects the idle and mixture. Opening it up (adding more fuel to the venturi by adding more air through the pilot circuit, confusing I know) should cause the idle to rise.
    Remember too that the colortune is ONLY for adjusting the idle circuit. This means that your idle must always be set at the manufacturer's recommended setting. If the idle is higher than that...poof, you're not running on just the pilot circuit, so your adjustments will have no effect. This balance usually takes a few tries, adjusting the pilot mixture, then the sync, and back and forth until everything lines up.
    If you like math, note that you are changing 5 independent variables (air mixtures in each pilot circuit, and idle speed) with 8 inputs (each pilot mixture screw, idle screw, and 3 sync screws). There are many combinations that will "seem" right at idle, but it's not until you're close to the right settings that you see meaningful variation with each input independently. Anytime I've doubted the colortune, I later found that the tool worked perfectly and was just telling me that something was still off.
  18. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I am forever baffled how stuff like this can coexist with the notion that carburetors are "simple" and "straightforward".
  19. JCH
    JCH Active Member
    seattle wash
    Back to the drawing board I suppose on the Color Tune issue I sure read about a Lot of others having the same issues ,not a believer yet... and at this point I would not recommend it to anyone I know, my carbs are spotless clean and the idle was at 1100 rpm while setting with the idle sync tool attached and you can tell a difference in idle quality while turning mixture screws, I just don't get it, must be missing something LOL,I would just love to get it to work like it is suppose to work ???
  20. ManBot13
    Fairfax, VA
    Simple in their operations (no feedback other than the slides) but they do require maintenance. The complexity here comes more from having 4 cylinders as opposed to 1 or 2.
    I've moved on to fuel injected motorcycles, and let me tell you, it is nice to just turn the key and start it up. However, if I started having trouble with the ignition system, a "good clean" would not cut it, troubleshooting would be a lot harder. My triumph ST1050 had a lot of off idle stumbles and surges. I was looking at ignition maps, throttle position sensor readings, throttle body syncing, connecting to the ODBII to a computer and TuneECU (that was more challenging than you might think). Turned out to just be the MAP sensor hoses were a little loose and that was only used off idle in the fuel map. Simple fix but a lot of troubleshooting for this shade-tree mechanic.
    I've taken about a 8 or 9 carbed projects in the last 10 years (most 4 cylinders) that haven't been run in ages and made them run like new. You just have to stick with it.
    For either poster having trouble with the colortune, have you done a compression test?
    chris123, Franz and k-moe like this.
  21. JCH
    JCH Active Member
    seattle wash
    No I haven't but I will, because it only has 9 K on the bike and has no severe drivability issues, it runs too good to have low compression.
    Cold Engine
    First pump 50 50 50 50
    Total 125 125 120 125
  22. k-moe
    Have you ever looked at the code that a modern fuel injection system runs?
    FI is simple for the end user; not so much for the tech, especially when setting it up or a different engine than it was originally intended to run.
  23. JPaganel
    Minneapolis
    No, never had the need to. But then again, I haven't looked up carb blueprints, either.
    Modern FI is tuned with GUI tools. Coding is about as common as milling a carburetor body from a blank.
    I've never seen an FI system set up on a different engine. Either they are where they were installed from factory, or they are something like Mega/Microsquirt, where it is being rolled new.
