How Tight is your Clutch Lever??
Discussion in 'XJ Technical Chat' started by CruiseAck, Aug 25, 2015.
  1. CruiseAck
    CruiseAck New Member
    Lancaster, Pa
    Hi XJers,
    My clutch lever is really tight, specially compared to my cb750, and most other bikes i have ridden(friends/coworkers/etc).
    I am wondering if thats just how they were designed or if there is something either wrong or something i can do to make it less stiff.
    It is operable by all means, but its pretty crazy going back and forth between different feeling bikes. Thats not really even the problem, but rather i just want to know the mechanics behind it, to see if there is anyway to change it.
    thanks everyone!
    Josh.
  2. CafeBlack
    CafeBlack Member
    Hi...my XJ900 requires the clutch lever to have little or no play in it. When I have adjusted it according to the Haynes manual (2-3mm of play from memory) it feels as though it doesn't disengage enough to kick it into first gear from neutral easily. Having it with no play just makes it feel like a normal shift into first. And this is with a rebuilt clutch with new friction plates.
  3. k-moe
    Clarify what you mean by tightness. Are you describing the force required to pull the lever, or are you describing the free play in the cable?
    CruiseAck likes this.
  4. CruiseAck
    Lancaster, Pa
    i am describing the force required to pull the lever. not free play.
  5. CafeBlack
    CafeBlack Member
    Good point. The XJ900 has a heavy pull on the leaver I've found. And when it has been really hard to pull the lever and disengage the clutch it has been down to a sticky/worn cable and on the last occasion it broke where the cable slotted into the lever. Apparently the friction put strain on the weakest point which was at the lever and the cable seemed to wear and break at the slotted end.
  6. Polock
    the little "barrel" on the end is supposed spin as you pull the lever. Remember the plastic thing on new cables, it's like a bearing to let it slide. Once the barrel sticks in the lever, your cable bends and won't last long. grease it up good
  7. pkay
    pkay Member
    Brisbane, Australia
    Check how tight the mounting nut and screw fir the lever are. If they are too tight you will create friction in the lever action that makes the pull action feel tight. If that doesn't work undo the lever and clean it out and regrease. Then check that it isn't overtightened. Then I'd check my cable condition including the bit above. If you've got it disconnected give the able an oil (never gets done). If problem persists after that let us know
  8. XJ550H
    get a cable lube block work great, clamps around cable and you spray cable lube in the little hole 5 seconds and it flows out the other end. my clutch pulls with 2 fingers
  9. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Check the arm at the top of the clutch cover it should point at a dimple on cover. With the arm at 90° to the cover it will get the most amount of leverage and a straight pull from the cable.
  10. CruiseAck
    Lancaster, Pa
    about to go through the checklist of everyones points. haha.. thanks for the thorough responses!!
  11. quebecois59
    I find my seca900 clutch lever a bit hard to pull compared to my Honda Magna 1995, even with a brand new clutch cable. The shifting is more accurate and les clunky though, I've never missed the second on the Seca
