How to Disable TCI for Compression Check?
Discussion in 'XJ Technical Chat' started by cdnjj, Mar 16, 2021.
  1. cdnjj
    cdnjj Member
    Vancouver, BC
    I read elsewhere it is good practice to disable the TCI for a compression test. Makes sense as it removes chance of arcing.
    How do I do this properly ? Is it just a matter of removing the 3 main connectors?
  2. Franz
    Yes remove the connector blocks from your TCI unit.
    Jetfixer likes this.
  3. k-moe
    Note that the TCI (box with the green label in your photo) only has two connecters. Unplug both.
  4. cdnjj
    cdnjj Member
    Vancouver, BC
    Thank you for the guidance. 120psi +/- 2 on a cold engine across all 4 which I think is ok.
  5. XJ550H
    good enough to run will likely increase once you get it running
    have you checcked valve shim clearances?
    XJ650 and XJ750 air-cooled engines:
    Minimum: 128 psi
    Standard: 156 psi
    Maximum: 171 psi
    Max. variance between lowest and highest: 14 psi
  6. Yammaat
    Yammaat Active Member
    Netherlands
    You could measure again with some oil on the pistons.
    Could make quite a difference.
