How to find a miss
Discussion in 'XJ Technical Chat' started by JBIII, Aug 28, 2008.
  1. JBIII
    JBIII New Member
    York, PA
    My 650XJ has a miss at about 3000rpm I had the carbs rebuilt a year ago and it started about a month ago. Don't know if it is a fuel or an electrical problem. Any ideas where I should start?? :(
  2. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    Mine did something similar til I noticed that the exhaust pipes were loose at the head.....
  3. Zookie400
    Zookie400 Active Member
    Connecticut
    set the idle to 3000rpm and measure the temps of the headers, if one is cold, thats your missing cylinder. if its a random/intermittant miss, this method wont work.
  4. PaulT
    PaulT Member
    Wilton, NH
    I found a miss on Match.com, now she's my Mrs. ;-)
  5. bluepotpie
    bluepotpie Member
    Londonderry, NH
    I hope she's not an intermittent miss. ;-)
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    You can check two things first. Pull the plugs right after it misses like doing a plug chop. See what cylinder looks like the culprit. Check you plug wires and caps. You might want to ohm them out anyway. Check the connections in that cap. Try it again if it has a miss. You can pull the carbs and see if that carb has dirt in it. I found one of my plug wires had a bad connection at the cap. I cut the wire back and made a new connection and that was it. Good Luck
