How To: Home Made Carb Sync Tool
Discussion in 'XJ Technical Chat' started by SLKid, Aug 12, 2013.
  1. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Go get yourself:
    3 pack Glass Baby Bottles from Wal-Mart $%
    ATF+4 Transmission Fluid $4
    2 Rubber Stopers. I Used #7 at Lowes. A little too big. Had to trim off some of the edges $4
    8 ft Fuel Line $9
    Youll need:
    A Drill
    Drill Bits
    Razor Blade
    Rubber Gloves
    Drill into the rubber stopper twice.
    I cut one piece, 2ft long, and then 2 pieces 3ft long. the 2ft goes from bottle to bottle
    the 3fts will run from bottle, to the intake nipples
    Insert fuel line into the holes. Lube withOne just needs to breach the bottom of the stopper. The other needs to be long enough to reach the bottom of the baby bottle Make sure you slide on the baby bottle caps before you insert the fuel line
    Fill the baby bottle 1/4 way with ATF+4. Press Rubber Stopper down into the bottle, screwing the top on. The stopper will want to push put. Thats ok, means a tight seal
    Repeat with 2nd bottle
    I hung the bottles by a tiny bungee I had, off the handlebars.
    No tipping or falling over, was pretty safe on the handlebars
    Heres the How To Sync!
    http://www.youtube.com/watch?feature=pl ... J1vWiHWW7s
    Any questions be sure to contact :)
    -Chris
  2. Joiner
    Joiner Member
    Delaware
    Love the saddle....boxes
  3. Polock
    when you do 1-2 you change 2-3 relationship, that's why you have to change 2-3 at the end. the order should be 1-2 , 3-4, 2-3
  4. SLKid
    SLKid Active Member
    Huh. I've always just started in the middle and double checked my work. As long as you feel confident when it's done is all that matters!
  5. wizard
    There is only one way, you line up 1&2 then 3&4 then 2&3.
  6. SLKid
    SLKid Active Member
    You heard em boys and girls!
  7. k-moe
    I was once very confident that if I jumped off of the roof I would fly.
  8. SLKid
    SLKid Active Member
    But now you are older and wiser and have forums to advise against doing such things
  9. boldstar
    boldstar Member
    ABERDEEN.SCOTLAND
    nice cheap and cheerfull tip well done bud
