How to lay down a bike
Discussion in 'Hangout Lounge' started by schooter, Jan 4, 2009.
  1. schooter
    I want to lay my bike down to clean and maint the underside, im just aprehensive on how to do it, i was thinking o turning the handle bars the opposite way you want to lay it down, and then lay pleanty of towels at all the contact points where the bike hits the ground, and then have somebody help me lay it down gently.... or i could somehow have it hover above the ground because we have hooks in the ceiling of our garage, so i can lay it down an then ratchet it up an inch, just osme thoughts..
    dont wory about loading up the carbs or flooding though, i have no carbs or gas tank...
  2. desertrat
    desertrat Member
    Moab, Utah
    last week i had to lay my girlfriends new 79xs400 down. the PO had stripped the head of the drain plug. I just carefully laid it on its side with blocks of 2x4s in strategic places to keep the bike off of the mufflers. Then I hammered a 16mm socket on to the stripped 17mm head, loosened the bolt, and stood the bike back up to finish the oil change
  3. turtlemann14
    turtlemann14 Member
    lay it down in soft grass
  4. schooter
    lol, kinda hard when its covered in a couple inches of snow, or ice..
  5. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Mattress from your parents' bed.
  6. TheHound
    TheHound Active Member
    Scotia, NY
    I thought this was gonig to be a story about a cold snowy nothern Michigan highway.
    :lol:
  7. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Easy! I used a cherry picker, engine hoist, to stack 4 XS650's on top of 4 other XS 650'S. This is an easy and safe way to lift a scooter off the ground without tipping it over onto the cold wet snow.
  8. coolalleycat
    coolalleycat New Member
    Cyprus
    If you haven't got a cherry picker...maybe you should try some helium balloons!...lol
