How to remove crankcase cover
Discussion in 'XJ Technical Chat' started by elliott, Apr 22, 2016.
  1. elliott
    elliott Member
    Utica, NY
    Hey guys,
    I'm attempting to rebuild my 85 XJ700 clutch with brand new parts from xj4ever. I read through the guide at http://xjbikes.com/forums/threads/clutches-101-part-1-the-400-550-600s-with-pics.29541/ but I somehow can't even get the crankcase cover off. I detached the clutch cable from the pivot shaft throw arm and removed all the crankcase cover bolts using a 5mm Allen wrench. Somehow the crankcase cover is still solidly connected. Is it the gasket seal that's just holding it in place? Do I have to remove the pivot arm completely before the cover can be removed?
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    After 30 years, the gasket gets baked on and the dowels get attached to their home. They can be tough to pull. Pry carefully (not on the gasket surface) and some smart blows from a rubber or deadblow mallet will get her moving.
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Start with a thin steal putty knife with the sharp edges filed off. Work your way around the cover. Then when a gap shows up then start to use wooden wedges.
    Just tell it to stay on so you can get the bolts back in. It will immediately fall off just to spite you.
    PilotSmack, jayrodoh and XJ550H like this.
  5. elliott
    elliott Member
    Utica, NY
    Hah! Yeah I ended up just holding a piece of wood to it and firmly smacking the wood with a mallet. Then it pulled right off.
  6. lostboy
    Makes you wanna do the happy dance!
