how to remove the gearbox neutral switch xj650
Discussion in 'XJ Technical Chat' started by glennyboy, Jul 23, 2022.
  1. glennyboy
    glennyboy Member
    central cali
    Can not get a socket in there does the engine have to come off mounts to remove.... its not screwed into the oil pan... does the oil pan have to come off
  2. glennyboy
    glennyboy Member
    central cali
    looks like the exhaust has to come off with the oil pan to get a socket in there....
  3. JCH
    JCH Active Member
    seattle wash
    On my bike I did remove the exhaust but not the oil pan and if my memory is correct the wiring was a bit of a pain.
  4. glennyboy
    glennyboy Member
    central cali
    JCH the wire coming off the switch is white then it plugs into a push connector now its black and red next to the frame, then inside harness up to the top next to the tdi grounding that wire does nothing grounding the blue/light blue wire next to it, back to normal again? could it be a sludge build up in the switch, engine was not started for 21 years. I drained the oil added two quarts of gas... drained and poured it back in while playing around with the gear lever, left for half hour drained ... still not working with test light grounded other end touching the switch i had a low voltage test low glow... back to ignition turning on dash lit up and relay clicked... now its ok... what did i do?
    Looking closer at the switch with exhaust off its much better but can not get socket in there, frame is slightly in the way, looks like the front engine mounts have to come off and lift engine about two inches.. hope i dont have to do that
  5. JCH
    JCH Active Member
    seattle wash
    I really don't remember having a issue removing the switch it self but I also have a lot of tools too, I heard of some cleaning the switch but with all the work involved replacing that switch I just purchased a new one from Len at XJ
    Not sure about your other question Sorry...
  6. Franz
    The pin on the plunger can wear on the neutral switch. That is what happened to mine. @chacal l think he sells a socket that is suitable for removing the neutral switch with the engine in the frame.
  7. k-moe
    Which XJ650? The Seca does have to have the exhaust collector removed for access, while the Maxim does not.
    You can cut the side of a socket so it will fit, or buy an already machined one from @chacal
    It sounds to me like your already getting it clean enough to work though.
    Stop using gasoline as a cleaning solvent. Buy a can of Seafoam and dose the oil according to the directions on the can. Then run the engine and if the bike is rideable, just ride it. That will safely get rid of the sludge buildup.
    Change the oil after about 100 miles though.
    Jetfixer likes this.
  8. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    it seems to me, you may me confusing the switches, gearbox neutral switch on most xj's, the wire is light blue,
    oil LEVEL switch has the "black red "wire
    which one are you trying to remove?
  9. glennyboy
    glennyboy Member
    central cali
    all sorted ...i was chasing the wrong wire lol :rolleyes::(.... yes its light blue... i never gave the clutch switch a thought if that was working i could have started it.... good old WD40 got it working
  10. stan burgess
    stan burgess New Member
    Choiceland Saskatchewan
    Changing my switch today and I did jack the motor up out of the motor mounts to get a socket in. Should have read this first and cut a side off a socket, oh well easier to get at the wire this way.
