How to service these forks?
Discussion in 'XJ Technical Chat' started by paulyc, Dec 5, 2016.
  1. paulyc
    paulyc New Member
    australia
    Hi guys,
    I need a little help regarding these forks on an '81 XJ550
    They have a 32mm tube. and looks like someone in the past has had a grab at the schrader valve with pliers or something.
    Anyway, I haven't seen these before and couldn't find anything via google.
    What am I looking at here? Is this a removable cap because it looks fixed?
    Anyone have any info on this type of top cap or how to service these things?
    That is the valve through which the air-spring in the shock is adjusted.
    The cap is removable.
    Put the forks back into the triple tree.
    Use a blunt object to press the cap down (because of the valve I'd suggest a deep-well socket), and a thin screwdriver or dental pick to pop the wire clip out (you can see the clip in your first photo).
    Beware, the spring will want to release quickly, so be ready.
  3. paulyc
    paulyc New Member
    australia
    Legend k-moe!
    Thanks so much for the detailed reply!
    Paul.
    Detailed!?
    That was the footnotes. ;)
    hogfiddles likes this.
  5. Simmy
    I use one of these to remove the circlip. Wrap some duct tape around the end of the fork so the c-clamp doesn't slip.
    As k-moe suggested you will need to cover the air valve with a socket. Screw in the centre threads against the socket then pick out the circlip.
    Release gently as you have the fork spring pushing up, be careful here.
  6. paulyc
    paulyc New Member
    australia
    That clamp is perfect, to be honest I hadn't even seen one before, probably because I've never needed it. Found they stock them locally to me for 10 bucks so all good.
    Small problem now is identifying exactly what fork I have to work out the oil amount. Everything I've seen so far points to this bike having a 35mm fork tube, but mine is 32mm.
    I'm in Australia, and although that doesn't necessarily mean the bike originated here, I'm also trying to figure out which variant I have of this bike.
    The one I have is a 1981 model and has the Maxim style tank and only a single left side caliper.
  7. k-moe
  8. paulyc
    paulyc New Member
    australia
    I have another question regarding these forks if someone could help...
    Mine are 32mm and everywhere I read they are 35mm, can't find anything referring to 32mm forks.
    Does anyone know how much oil go into the 32mm forks?
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard. You're gonna need a service manual.
    Gary H.
  10. k-moe
  11. k-moe
    Yep.
  12. XJ550H
    XJ550 Seca fork tubes are 35mm OD, The XJ550 Seca models are the "baby fork tubes" of the entire XJ series, which is very odd.
    my xj550H maxim are 36mm
    32mm is an odd size and with the disc on the left is a seca thing maxim is on the right as you sit on bike
    the air valve is not a stock maxim thing. I did just see them on ebay for the 550
    seca and maxim use different amounts of fork oil
    maxim
    seca
  13. XJ550H
    your photo shows axel in center of fork tube another seca
    what size is your rear tire? 16 or 18 inch
    110/90-18 rear is a seca tire
    130/90-16 is maxim tire
    swirley rims are maxim in US but seca in europe
    you need to check the vin number link that was provided both frame and motor to properly ID the bike
  14. chacal
    Yes 32mm OD fork tubes are a problem..........certainly not correct for an XJ550 of any stripe, and the trick will be in figuring out what bike they came off of (so you can obtain the proper rebuild parts). They must have switched out the steering brackets, too............
  15. Toomanybikes
    Tsawwassen bc
    Even the 400 Maxim uses a 35 mm fork?
  16. k-moe
    He's in Australia, and I think he has a JDM import, so the fork tubes are likely correct. He'll also need a JDM manual, and learn to read Kanji :(
    What I'd do is fill the forks to about 6" from the top of the collapsed tubes, then go for a ride and see what it fels like. The other way is to do some math to figure what the height of the oil column is in the 35mm forks, and scale that down to suit the 32mm forks.
  17. rocs82650
    Middle Tennessee
    +1.
    Gary H.
  18. paulyc
    paulyc New Member
    australia
    Thanks for all the replies and suggestions.
    I have a manual for the bike, but it only points to the 35mm fork so no luck there.
    I have matching engine and vin numbers, and using those points my model at being the H variant, and it only has the one brake/rotor as well.
    The other thing I might try is finding another Yamaha that might use the same fork type?
