I finally got X#2 on the road
Discussion in 'XJ Modifications' started by Desinger_Mike, Apr 12, 2008.
  1. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    I finally got it out on the road today.
    Thanks to Gamaru and Painter D for the help with the paiting process.
    And all others that offered mechanical know-how.
    More photos in my gallery, but I must warn you they are pretty big right now.
    another view
    Bought it with a blown engine then bought a parts engine on E-bay.
    Inspected the top end, rebuild the carbs (and a little paint), POR15 in the tank, all new wheel bearings, steering bearings, brake pads, fork seals, and a lot of elbow grease.
    Thanks to Twerth for the speedo and engine side covers.
    And it even runs! :D
  2. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Gorgeous looking bike! Well done.
  3. chacal
    too cool............
  4. willierides
    willierides Member
    NY
    VERY NICE! The seat looks great. The engine....heck, the whole bike looks great!
  5. twerth
    twerth Member
    Parkville, MO
    Nice work Mike. You have to see the before and after pictures of the engine to appreciate the effort that went into this bike.
  6. Desinger_Mike
  7. cereal_killer
    cereal_killer Member
    Baja Mason Dixon Line, East of Honolulu
    Great looking bike! What color blue is that?
  8. Desinger_Mike
    Don't laugh....it's blue metalcast by duplicolor!
    http://duplicolor.com/products/metalcast.html
    You put a "ground coat" down, and then the "color" coats.
    If you have the talent, you can control the darkness of the color, but I'm lucky if I can get a smooth surface much less worry about the depth of color.
    It's similar to a candy process I believe.
    It has some depth to it, and goes on pretty well considering it's a $6 rattle can you can get anywhere.
    I went over it with the 2 part clear coat that Gamaru used. That part is highly recommended if you don't have a real gun to use the automotive grade clear coat.
    At the end of the day, I wish I would have just paid someone to paint it. Lots of time spent, and I didn't get 100% perfect results.
    Next time I would either go through the pain of mixing and cleaning in a real gun or pay someone to do it for me....but if you got the time, patience, and want to save some $ it can turn out nice. There is a certain satisfaction that comes with "I did that" factor too.
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Looks good Desinger!!
    The rattle cans will never give you an atomotive type finish, no matter how much sanding or anything else you do, period. It will be good enough to get you by and look good enough going down the road, but that's it.
    I've done it more times than I want to remember. Looking "good enough" is one thing, but spilling a bit of gas on it is another. It just don't have the protection and stains when gas is introduced to it.
    ..."Gas, meet spray paint. Now go ahead ans start eating it!!!"
    I finally decided to get a spray gun and do it right. You can get a great finish and better protection from a dreaded gas spill with enamel paint that uses and activator/hardener in it. It has a better shine and really stands up to gas.
    I just got done painting mine with implement paint (made for farm equipment) and I am happy with the results. I filled the tank with gas when it was cool out when I rode last week just before I rode it home (about 1 mile away) and parked it in the shed. after the bike warmed up a bit from being outside, the gas must've expanded in the tank and started to run out the gas cap and down the side of the tank onto the floor.
    I didn't notice it right away, but when I came back into the shop about an hour later, I noticed a little puddle on the floor under the bike. Then I figured out what happened. I wiped the gas off the tank with a soft rag and rubbed it shinny again. The paint looked like new, no stain or marks in the paint what so ever!!! Now I'm convinced I made the right choice with the paint I used.
    I'm done with rattle cans. Get a cheap spray gun (you can buy a cheap touchup gun in Ebay for less than $30) and use a paint with hardener in it. You will be happy you did!! PD
  10. willierides
    willierides Member
    NY
    I have some decent spray guns, but chose to rattle can the Maxim. I had the problem with gas eating my paint, too. But I did find another option that works. I bought something called "Engine" clear coat.....or something like that.....for clear coating engines. It worked. It does not suffer damage from gas. Unfortunately I had already done the spill-gas-on-tank-re-sand-re-paint-re-clear routine several times so my paint job is still buggered up. Also, I JUST put some bars on to replace my straight drag bars and make it so my left hand controls clear the tank at full left lock, so there is also a nice ding in the paint there. I'll wait until next winter. I hope to have a "booth" set up at my new house by then and will do a new paint scheme using my HVLP gun, compressor etc.
    But the engine-rated clear coat stands up to the gas.
  11. Desinger_Mike
    I also have two guns, but I hate all the mixing, clean up, and the added overspray.
    I really want to test the 2K clearcoat to see if it stands up to gas as good as automotive, but silly me...I didn't do a test-piece that I could run through some harsh testing (and now the can is a rock)
    http://www.uschem.com/products/docs/Spr ... 20(English).pdf
  12. PainterD
    Deinger-mike,
    That stuff is supposed to be good for protecting the tank against spills. I used the high temp clear coat (Duplicolor) and it does protect to a point. It will not eat thru the clear coat but it seems to lose it's shine from gas and needs to be buffed out after a gas spill.
    I used an HVLP touchup gun on mine so I didn't have much over spray in the shop. Before I got the gun, I always just used my airbrush to paint. It didn't cover as heavy and I found I needed to give it 3 coats because the mist is so fine. The touchup gun really does a nice job with just two coats and takes alot less time. PD
  13. MikeT
    MikeT Member
    Newfoundland, Canada
    Desingner Mike, PM sent!!
