I know I'm not Going to Like the Answer to This
Discussion in 'XJ Technical Chat' started by AnejoMofo, Mar 10, 2008.
  1. AnejoMofo
    AnejoMofo Member
    Highest taxes, worst roads.
    Hopefully, this is a naive question with a simple answer. Probably not.
    When my 1982 XJ750 J (shaft drive) is up on the center stand with the engine idling in neutral the real wheel rotates slowly in its normal direction for forward travel. This is not gravity related. If it is stopped, it will continue rotating of its own free will. If it is manually spun backwards there is a small amount of resistance and the wheel eventually begins to rotate once again. The period of the wheel's rotation is about 60RPM. The rotation speed increases when the throttle is opened. If I pull the clutch in there is absolutely not difference in this phenomenon. What causes this? :|
    Help a brother out,
    -AM
  2. Jon81550Maxim
    Jon81550Maxim Member
    N.Ontario
    I think it's the rotating momentum of the running engine through the transmission.
    Even though the transmission isn't in gear, the spinning of the main driven shaft is having an effect on the other transmission shafts. When it's in neutral your 1 through 5 gears arn't engaged but the shaft still turns.
    The oil on the shaft might also affect this, as subtle friction.
    If I remember correctly.
    Hope this helps
  3. CharlesCollins
    CharlesCollins Member
    Milwaukee, WI
    I have the same thing going on with my '81 550. So...not an issue?
  4. MiCarl
    The gears in the transmission are always meshed. When "in gear" one of them will be slid along it's shaft so the dogs on the side of it engage a neighboring gear. When not "in gear" they spin on the shaft that passes through them. There is some drag in those bearings, so it will spin the real wheel when it is free.
    The clutch plates are in close proximity, in an oil bath, so there is also some drag there.
    Completely normal. We all do it.
  5. blackjack550
    blackjack550 Member
    san pedro california
    hey charles i thought that 550s were all chain driven how did u come across a shaft drive or is my former information wrong?
  6. AnejoMofo
    AnejoMofo Member
    Thanks for the responses guys. I cannot believe this isn't a major mechanical problem. My luck has changed. I don't often run the bike while it's on the center stand so I only recently noticed this. I guess I do like the answer!
    Thanks again,
    -AM
  7. CharlesCollins
    Milwaukee, WI
    Nah, you have it right. The 550 is chain driven... I only meant that I have the same 'symptom' as AnejoMofo.
  8. mcrwt644
    mcrwt644 Member
    Winchester, VA
    every, and I mean every (I've had over forty) bike I have owned did this.
