I Need a YCIS Emblem
Discussion in 'For Sale, Trade/Swap, Wanted' started by ChrisRomello, Jan 11, 2014.
  1. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    When I was pressure washing my engine before I took it apart for a rebuild I blasted off one of my YCIS emblems on the side crank cover and it is nowhere to be found. If anyone has an old engine or one laying around please let me know!
    Just PM chacal
    XJ4ever
    Engine Cover Emblems:
    The crankshaft end cover YICS EMBLEMS feature a self-adhesive backing and have the red raised, stylized "YICS" wording against a flat-black background as original.
    HCP19165 Aftermarket left or right side OIL PUMP COVER EMBLEM "YICS", embossed black rectangular emblem with raised red lettering. For all YICS motors (XJ550, 1982-up XJ650 Maxim and Turbo, XJ750 air-cooled, 1983 XJ900, and XJ1100 models. Uses supplied adhesive tape to mount emblem. NOTE: you must remove all traces of prior adhesive from the cover before installing new emblems. If you want to install the new emblem on top of the original emblem (this will make the new emblem "stand proud" of the recess, and gives a unique look to the emblem), then we recommend the use of our HCP3120 adhesive material during installation. Each:
    $ 18.95
    HCP19165SET2 Aftermarket left or right side OIL PUMP COVER EMBLEMS "YICS", embossed black rectangular emblem with raised red lettering. Set of 2:
    $ 34.95
    HCP3120 Aftermarket black GASKET MAKER, 3.8 ounce squeeze tube pure silicone RTV material is good up to 500-F. Enough to do about five hundred emblems! But it's the smallest size offered. I'm sure it works well in other applications. Each:
    $ 7.95
  3. bigfitz52
  4. hogfiddles
    ditto......except Chacal only sells the YICS emblems, not YCIS emblems. :)
    dave
  5. schmuckaholic
    California
    You mean that isn't Yamaha Carburetor Investigative Service? :p
  6. k-moe
    Hey now. Some of us are sydlexic.
