I think the 82 SECA 750 I just got needs a starter clutch
Discussion in 'XJ Technical Chat' started by volsrock1963, Jun 6, 2025.
  1. volsrock1963
    volsrock1963 Member
    Kansas City
    I think the 82 SECA 750 I just got needs a starter clutch....It starts fir cold like a new bike but when hot noise from hell starts after about 4 5 trys...IDK what kind of oil is in it and the battery starts it when cold but spins starter when hot and noise...but even after being on 2 amp charger all not the green charge is still flashing....has 20k miles
  2. volsrock1963
    volsrock1963 Member
    Kansas City
    Why would it not do it while cold...the battery in it gets crappy reviews like 2.2 out of 5
  3. volsrock1963
    volsrock1963 Member
    Kansas City
    And if it was the battery or oil would it do it while cold also?
  4. Franz
    Use only JASO rated oil some oils cause problems with wet clutches and starter clutch. Rotella T4 is good l believe. Slippage when hot is because the engine oil is thinner or is the wrong oil .
  5. Franz
  6. Dan Gardner
    Minneapolis, MN
    The clutch just gets worse with heat.
    If I were you I'd check out K-Moe's write up and run Rotella T4 15W-40 and hope for the best, but prepare for the worst. Worst case is you have to live with it for a while - it's not like some sort of urgent situation. Just a pain in the butt when the bike is hot.
  7. volsrock1963
    volsrock1963 Member
    Kansas City
    Well I guess the battery is ok ...volts drop to around 10 while starting while cold
  8. volsrock1963
    volsrock1963 Member
    Kansas City
    What is time do the labor this job at a shop... There is a guy here in town that specializes in working on older bikes he will do this but he's on vacation in Florida I won't be able to get a hold of him for his labor time.... That's why I'm asking what should I expect if he tells me 12 hours is that too long
  9. volsrock1963
    volsrock1963 Member
    Kansas City
    Well the classic shop texted me back said around 1500
  10. Franz
    With the engine out of the frame it could be done in a few hours, it is not that big of a job. Do you have the time and knowledge to do the repair yourself or are you too busy hence the shop option?
  11. Franz
  12. volsrock1963
    volsrock1963 Member
    Kansas City
    What can or should also be replaced while in there
  13. Franz
    Change the starter chain guide, its old and if it breaks up will affect gear selection, check the oil spray nozzle which should have no marks from the chain. The guide bolts apply heat before removing them to soften the factory loctite. Get new bolts torque to spec 10Nm.
  14. volsrock1963
    volsrock1963 Member
    Kansas City
    I changed the oil to Shell T4 it seemed to help a little
    But with all that notice from the starter clutch why wasn't there some shavings in my old oil? And on the drain plug
  15. Franz
    Shavings don't come off the rollers, they must be hardened. Weak springs might be the cause.
    chacal likes this.
  16. volsrock1963
    volsrock1963 Member
    Kansas City
    Think I will see if it makes it though the summer IF it last that long and replace it in the winter
  17. Dan Gardner
    Minneapolis, MN
    I think it’ll last the summer. Mine has lasted several. Just might be a little embarrassing when you’re in a crowded parking lot when the bike is hot and you try to start it.
    If it is a problem when the bike is cold, then you need to worry.
    If I were you I would change oil again relatively soon just to make sure to get rid of whatever was in there.
    chacal likes this.
  18. Franz
    Yes well winter is a good time to replace it.
  19. Franz
    Jetfixer had the same problem with starting his bike when hot, it still lasted some time before he had to replace it.
  20. volsrock1963
    volsrock1963 Member
    Kansas City
    Starts fine when cold and semi warm...its only when hot
  21. Dan Gardner
    Minneapolis, MN
    You’ll be fine for as long as you’re willing to live with it. I just know that when I stop to pick up a 12 pack of beverages on an 85 degree day that I might get a can of marbles. Eventually it starts after a couple of attempts. Worst case I’d have to push start. Not a big deal. Thus far I have not had to resort to push start.
  22. volsrock1963
    volsrock1963 Member
    Kansas City
    31A-15580-00-00
    4H7-15580-10-00
    Which one I come up with these 2 diff part #s for a 1982 Seca 750...one cost more
    The 31A also will fit a 2009 Yamaha YFM250 Big Bear so I am confused
  23. volsrock1963
    volsrock1963 Member
    Kansas City
    It wont damage the engine crank etc??
  24. Dan Gardner
    Minneapolis, MN
    See here: https://www.xjbikes.com/forums/threads/1982-xj750-seca-starter-clutch-part-numbers.132492/
    The TLDR is that the 31A part number is a later iteration with some heavier springs but will work in the 650/750 - in fact, could be considered an upgrade.
  25. Dan Gardner
    Minneapolis, MN
    No
  26. volsrock1963
    volsrock1963 Member
    Kansas City
  27. volsrock1963
    volsrock1963 Member
    Kansas City
    And what other parts do I need to get to do the job??
  28. volsrock1963
    volsrock1963 Member
    Kansas City
  29. Franz
    Get new chain guide bolts, the guide itself, sealant for the cases and oil seals and o rings.
  30. volsrock1963
    volsrock1963 Member
    Kansas City
    Cam chain guide?
  31. Franz
    No the guide in the crankcase for the hi vo starter clutch chain. Its secured to the upper case with two, sometimes three bolts.
  32. Franz
  33. volsrock1963
    volsrock1963 Member
    Kansas City
  34. chacal
    As much work as it is to get into the case and replace the starter clutch, I would think twice about ordering the low-cost China clutch......as you definitely don't want to be doing this type of surgery again!
  35. volsrock1963
    volsrock1963 Member
    Kansas City
    OK so which one do u get?
    The one at partzilla Part #:31A-15580-00-00 is 224.00
    Same part number on ebay is 93.00....how do we know they are not BOTH from Chins?
  36. volsrock1963
    volsrock1963 Member
    Kansas City
    Do u have one?
  37. Franz
    You can contract Chacal on info@xj4ever.com he will give you the information you need.
