I think this use to be an XJ...
Discussion in 'XJ Technical Chat' started by Metal_Bob, Mar 29, 2012.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
  2. RSpark
    RSpark Member
    Dubuque, IA 52001
    Whoever did that belongs in a gas chamber or on the end of a rope...... That is a travesty
  3. Dannymax
    Dannymax Member
    East central NY
    I wouldn't expect much out of that guy....look who he hangs with!
  4. Massimo33
    Massimo33 Member
    Denver, CO
    It's like looking at a train wreck, it's so bad I can't believe it, but at the same time I find it quite fascinating, so that I can't quit looking at it.
  5. Metal_Bob
    Bourbonnais, IL
    So... Rat bikes are made to look bad/worn/decorated but how well are they typically maintained under the grime?
  6. mtnbikecrazy55
    Idk, but I would guess in this case not so much, lol.
  7. hogfiddles
    I'm with massimo on this one......I'm normally a purist, but have that latent part of me that has always toyed with doing a rat just to do one. Now THIS-------------looks like what I'd try to do. Yup, it's SO bad....BEYOND bad, that it's intriguing. I MAY just contemplate it even more :)
    I'd also have to agree with Bob...... now really, do you think this guy would EVER let HIS bike be the one that breaks down? The rest of them would be UN-merciful!!!!! Nah, I bet it runs like a top.........and those back brakes are probably hopped up to 'compensate' for any frontal lobotomy (well, on the BIKE, I mean.....)
    Didn't meant to offend you, OWNER, if you're one of us! LOL
    dave Fox
  8. hogfiddles
    Looking at that again..........
    Dying laughing at the rat on top of the handlbars, and the 'airhorn'.
    Obviously the guy put a lot of thought into it..... dvery square inch of it has something nasty on, in, or done, to it. I keep finding more the longer I stare at it........kind of like a dog returning to its own puke....
    Maybe that bike should be called a X-Maxim (as in EX-Maxim) LOL
    If I DO do that, I'd turn the front rim around, too, so the spokes swirl the opposite way :p
  9. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    He overlooked one little detail though, the throttle grip is still shiny
  10. hogfiddles
    That's to satisfy the harley-wannabe part of him. A small caveat........
    dave
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Bikes and drugs, nuff said!
  12. hogfiddles
    Seeing more stuff on there...
    ... the indian face at the seat back
    ... looks like a beer tap at the top of the welded-chain 'backrest'
    ...nTHE ELECTRICAL OUTLET in place of the frame reflector!!!!!!
    ...nevery line a different color on the valve cover
    ... the gas mask
    ... flat-plate side cover
    ... the ubiquitous ammo-can
    .... the hysterically broken headlight mount-- which, by the way, appears to have the mounting points on the sides of the lower triple clamp and that indicates that this is probably an XJ550 maxim. Thereby, that satisfies the chain-drive crowd........and the chain is probably painted some crazy color...let's say, uh, greasy rust color?!?!?!
    --and I'm still studying it, as well as the other bikes.
    Dave Fox
  13. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Yall DO know that this was Photoshopped right?
    60% of it at least
  14. darkfibre
    darkfibre Member
    Perth, Australia
    With no front brakes, one would hope he checked the rears for delamination.
  15. mtnbikecrazy55
    dont shit on my rainbow now...
  16. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    SLKid, how do you know it was photoshopped?
    Styling wise, it looks pretty much like a number of things I have seen people post here as projects ... the decorations are the only difference.
    One does have to wonder about the lack of brake rotor on the front wheel ...
    If it was photoshopped, does that mean that it a non-op bike or did someone just photoshop the decorations?
  17. SLKid
    SLKid Active Member
    Looks like a lot of the Funky decor was photoshopped. I know, cause I was a graphic designer. Zoom in on some of the colors and take a look at the pixel resolution.
    Who knows! She might be an operating motorcycle! Should ask the guy
  18. hogfiddles
    I have no reason to doubt that it's a real bike. If the rotor was photoshoped out, for example, then caliper, lines, everything, would have to be cut, too. I can't find ANY thing there to indicate that anything has been digitally removed.
    fwiw,
    dave F
  19. mook1al
    mook1al Member
    Talladega, AL
    Well, he'll save on front brake maintenance.
  20. XJNEWFIE
    XJNEWFIE Member
    St. John's, NL
