i would change the butter maiden front forks...
Discussion in 'XJ Modifications' started by luxio, Mar 29, 2009.
  1. luxio
    luxio Member
    italy
    the front forks of xj900 will fit in the the frame of the xj650?
    there are other models that fit in the xj650?
    thanks
  2. Deadulus
    Deadulus Member
    Dufur, Oregon
    I seem to remember xj750 forks will work, but are dual disk, so you would need the Master cylinder and brake lines also....
  3. bigfitz52
    How about just upgrade the fork springs and go to a slightly heavier fork oil?
  4. panaflax
    panaflax New Member
    let me know how this works out, I'm having problems with the front fender bashing the exhaust pipes, and they also feel way too squishy. rebuild with stiffer springs? upgrade? thicker oil? im on a 80 xj650
  5. Hillsy
    Hillsy Member
    Your springs have sagged. A quick fix is extra spacers under the fork caps, a better fix is new "progressive" springs.
    Oil only controls the damping, not the fork travel, but heavier weight oil will help make the forks feel "stiffer". 15 weight oil would be a good start.
  6. luxio
    luxio Member
    italy
    progressive springs are too expansive. i think it's better buying used forks on ebay 'cause my my seca has dual disc too.
  7. Deadulus
    Deadulus Member
    Dufur, Oregon
    How much WOULD progressive springs run?
  8. chacal
    About $70/pair............
  9. bigfitz52
    Which is probably cheaper than any eBay deal and a very worthwhile upgrade. Progressive's springs and 15W fork oil completely transformed the front suspension on my '83 550 Seca, and it WASN'T sagged out yet.
  10. luxio
    luxio Member
    italy
    fixed, i have changed the oil with an oil for the gears of the trucks.
    now is a little bit hard, but better then earlier.
