idle adjustment
Discussion in 'XJ Technical Chat' started by ant797, Nov 14, 2015.
  1. ant797
    ant797 Member
    western australia
    anyone know where an how to adjust the idle xj750 it wont idle without choke and of course maybe riding it with choke is causing it to chug
    Sounds like a dirty carb problem rathar than an idle knob problem.
    Nevertheless, the idle adjustment knob is located between the #2 and #3 carb floatbowls. Easiest access is from the right side of the bike. Wear a heat-resistant glove, 'cause you'll want to adjust it when the engine is at operating temperature.
  3. hogfiddles
    Clean your carbs ( Church of Clean clean)
    Check/adjust your valve clearances
    THEN worry about idle speed when you're syncing the bike
  4. ant797
    ant797 Member
    western australia
    the carbies been cleaned only had this problem since i got them back thanks blokes for the info
  5. k-moe
    If the idle adjustment dosen't help, then please report back as to how the carbs were cleaned. Not being able to idle without choke can be a sign of failed throttle shaft seals (among other things).
  6. ant797
    ant797 Member
    western australia
    can idle without choke now and rides a bit better seems to be running a little rich but i broke a spark plug wire taking it off and its just sitting there with little insulation i have new one on order the only other problem i have is i just got the indicators and horn working and last ride i had none of that is working and theres no indicator signals on dash either i had those before i fixed this last time
  7. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Classic restricted pilot circuits problem having to run the choke to get these XJ's to idle. Your carbs may have been cleaned but maybe whoever did it overlooked some of the passages that involve the pilot circuits.
  8. hogfiddles
    Who cleaned them?
    How did the clean them?
    EXACTLY how did the clean them?
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I agree with the others...if the mix screws are between 2.5 and 2.75 turns out and it won't idle w/o the ec the problem is in the carbs.
    Gary H.
  10. k-moe
    You have a new spark plug wire ordered? They are integral to the coils. Are you splicing in the new wire?
    If it's still not running correctly then you do need to revisit the carbs. You should not be running rich. When fully sorted an XJ can be compared favorably to a new inline four in terms of sound and feel.
  11. ant797
    ant797 Member
    western australia
    it was idling ultra low on choke before i adjusted the idle at the carbs ..im not replacing the whole coil wire just the end bit that goes on the spark plug.. i had the carbs cleaned at a motorcycle engineers he told me the float needles where very warn but there still holding ..maybe i should order some kits from taiwan they come with all new jets and needles seems to be more in them then the ones from america and uk http://www.ebay.com.au/itm/Carburet...920277?hash=item4199c860d5:g:ZD8AAOSw3ydVqsSV
  12. hogfiddles
    Order from xj4ever. Otherwise, you'll fight and fight and fight, find out the problem is with the eBay kits you bought, end up ordering from xj4ever ANYWAY..... When you could have saved your money and just ordered the right stuff to begin with....
    Hmm float needles "very worn but holding", huh? Yyyeah, riiiigghht ......
    And just how did he determine that they are ' very worn'? I think it would be a big help for US to know how to determine that, too--
    FWIW
    Dave F
    Stumplifter likes this.
  13. ant797
    ant797 Member
    western australia
    thanks guys think its all good now
  14. Ezekiel Gavieres
    Ezekiel Gavieres New Member
    New Jersey
    How did you end up fixing the issue?
  15. hogfiddles
    5.5 yrs later.
    Ant797 hasn’t been seen since August 20, 2016
  16. Toyobaru866
    Toyobaru866 Active Member
    Netherlands
    And it doesn't look like he was willing to take some good advice...
  17. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Probably just sold the bike and moved on.
    hogfiddles likes this.
