Idle problem
Discussion in 'Hangout Lounge' started by dmlyster, Sep 1, 2012.
  1. dmlyster
    dmlyster Member
    Corvallis, Oregon
    83 XJ 750 K. Gas tank a mess when I got it. Cleaned up well. Starts fine with choke and idles at spec (1000 rpm). After riding for a few miles the idle increases.
    When hot and at idle I now get 2500 rpm. Will not resume spec idle until shut down and cooled. Anyone have any ideas as to cause?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Valve adjustmants need to be checked and in spec first.
    Then check carbs;
    Float levels correct?
    Any vacuum leaks? Throttle shaft seals and carb boots are always a problem
    Carbs sync properly?
    Has a compression test been done to ensure the motor is healthy?
    Your symptons point to a possible vacuum leak.
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Set the idle when fully hot, that's why there's choke when it's cold.
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    agree. from experience.
  5. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks All!! Setting the idle with engine hot seems to have solved my problem. I still need to work on carb valve adjustment but will hold that project for the winter. Thanks again for all your comments.
