Ignition issues
Discussion in 'XJ Technical Chat' started by Chris J Baker, Dec 26, 2016.
  1. Chris J Baker
    Chris J Baker New Member
    Soldier ks
    So I'm fairly new to working on bikes and came across and issue with my 1981 yamaha 750 I believe it's maxim the guy who sold it to me said it's a seca but I can find a maxim in that year but the issue is that the black plastic piece on the ignition that holds the wired and Cooper pieces broke and I can't find a or part or match for it any wired diagrams or advice would be greatly needed thank you
    You could have either a Seca 750 or a Maxim 750, as both were produced.
    TECH TOPIC: Model ID and VIN's
    By ignition I assume you mean the keyswitch. Start a conversation with Chacal, He has band-new replacements.
    Start by reading The Information Overload Hour. Assume that none of the required maintenance has ever been done. Get that all caught up on, and you'll have a very reliable machine.
  3. hogfiddles
    Iirc, the ignition switch base shape is as follows:
    750 maxim-Basically a triangle-ish shape
    750 seca - basically a "T" sort-of shape
    Relatively speaking
  4. Toomanybikes
    Tsawwassen bc
    image.jpg This is broken?
  5. Chris J Baker
    Soldier ks
    Yes that piece it's shattered
  6. Toomanybikes
    Tsawwassen bc
    I'm guessing that ignition was hammered out ,that is what will cause that to happen.
    Post a pic of your bike and ignition switch and we'll help you Identify the bike and correct switch you need
  7. Chris J Baker
    Soldier ks
    I got the new ignition it's the exact same one all the way down to plug but no powere to hud or ignition
  8. Chris J Baker
    Soldier ks
    It has three turn positions and no matter what position it's in nothing lights up I remember when I turned the key before the neutral light always went on
  9. k-moe
    Have you thoroughly investigated the condition of the fuse box? The originals have fuse clips that can fail from age, but look perfectly fine whn viewed from above. Glass fuses can also look perfectly fine, but in a failed state below the metal end where you can't see.
    Are you sure that the battery is charged?
    Stumplifter likes this.
  10. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Are you in neutral?
  11. XJ550H
    check for voltage at the main fuse, and the clips.
    check for continuity from main fuse output side to the connector for the ignition key. red wire
    then check for continuity from same connector back to the other fuses it should be the brown wire
  12. Chris J Baker
    Soldier ks
    Xj550h you were right it was the fuse thank you
  13. Chris J Baker
    Soldier ks
    Thank all of you for the information it really helped and it taught me a lot about my bike
  14. Stumplifter
    near Irma, WI
    Hang around you will learn a whole lot more! :D
    rocs82650, chacal and k-moe like this.
  15. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Ditto to that!
  16. k-moe
    Like the three B's.
    MattiThundrrr and Stumplifter like this.
  17. XJ550H
    it was k-moe who told you to check out your fuses, I was telling you how to chase the voltages from battery to ignition switch and back to fuse box.
    nice that it turned out to be a blown/bad fuse
