Important head/cylinder bolt question
Discussion in 'XJ Technical Chat' started by ChrisRomello, Dec 29, 2013.
  1. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    I removed the head and cylinders on my xj650 Maxim yesterday and when I got the cylinders off there was these plastic-like sleaves that crumbled off of the bolts. I think they are supposed to be spacers to keep the cylinders on tight or something but I mreally concerned about it. Can I replace these? or is there some sort of alternative? Below are some pics.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    They're replaceable. Len has them.
    Edit: The oil transfer washers under the cap nuts on the far right side that Fitz is talking about are the only two copper washers of the lot.
  3. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    What are they called?
  4. Polock
    I wiped mine off put some grease on them and slid on some heat shrink
  5. bigfitz52
    They're called "cylinder head-to-crankcase black plastic, high-heat SHEATHING."
    More important is that big cam chain gallery seal. If it's crispy/crunchy/crumbling, it needs to be replaced and no, it's not cheap.
    Also be very aware of the o-rings that go around the dowel pins for the head bolts on the RH side. The RH outer head bolt passages are actually the oil feeds to the top end; the washers under those cap nuts are sealing washers that also need to be replaced.
  6. moellear
    moellear Member
    Lima, Ohio
    I learned this the hard way, and try to remind people to replace 'em too. Good call
  7. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    Can someone send me a link to some of those plastic heat sleeve things? Thanks!
  8. moellear
    moellear Member
    Lima, Ohio
    I'd just get in contact with Len at info@xj4ever.com
    Sure you could do an extensive search on yamahapartshouse.com and look up the part number yourself but Len is a trustworthy guy on this site
  9. rocs82650
    Middle Tennessee
    x1^. Len and xj4ever provide great service to this forum.
  10. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    Do I need one of these for every bolt on the engine?
  11. 750E-II_29Rbloke
    South Cheshire, UK
    Len (username- chacal) will know, and he won't sell you more than you need anyway, seriously he's a great guy who's in it for the love of the bikes not to get rich & anyone who's had dealings with him I'm sure would 100% recommend him to you. ;)
  12. Sam patton
    Sam patton New Member
    Grass Valley
    What is the purpose of the sheathing around the head bolts?
  13. k-moe
    Noise reduction mainly.
