important reminder when doing carbs!
Discussion in 'XJ Technical Chat' started by cheezehead, Jun 29, 2008.
  1. cheezehead
    cheezehead New Member
    northern wisconsin
    don't do as i did. cleaned them again, bike ran worse. thinking that i have an electrical problem, i checked the coils, ok. still missing at mid rpm. pull carbs again. i pulled all the float bowls off, then flipped the rack over. i noticed one float hanging lower than the rest. i thought i broke the little tab for adj. the float level. nope, just installed it upside down!! what a maroon! now i can ride!
  2. MiCarl
    Yeah, they actually look "better" upside down. Common mistake.
  3. wizard
    Yeh, when I got to putting back #4 it didn't look right, I ended up taking them all off again just to check!
  4. gazzafield
    gazzafield New Member
    Just how do you install a float upside down? I'm assuming this is what you did as the tab for adjusting the float height is attached to it. Or am I just thick?
  5. weoxstan
    weoxstan Member
    Central Michigan
    Been there, done that! It is a easy but annoying fix.
  6. CdnDave77
    CdnDave77 Member
    Norwich, Ontario, Canada
    I plead guilty as well... Did it my last rebuild. You'd think after having them apart 3 times, I would have been ok.
  7. cheezehead
    northern wisconsin
    well, i guess i feel right at home!
  8. igormothra
    igormothra New Member
    Lewes, DE
    Just out of curiosity does anyone have a pic of what they are supposed to look like? I took mine apart and cleaned them tonight and put them back exactly the way they came apart but I just want to make sure the last person who did it did it right.... cause they were amazingly clean....
  9. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    Don't know what kind of carbs or floats you guys are talking about. But it is impossible for me to install my floats upside down. Either I would have to force the float bowls down on the carb body, or they would simply look wrong before I even attempted to install the float bowls. I have an XJ550 with the Mikuni carbs.
  10. Deano750Maxim
    Deano750Maxim New Member
    Warsaw, IN
    OK, now you guys are making me paranoid.
    I just bought a non-running Maxim and I rebuilt the carbs. It starts now but it is really running rich and now I'm wondering if I put the floats in wrong. Ugggg.....
  11. wizard
    EXPLODED HITACHI
