inner tube ?
Discussion in 'XJ Technical Chat' started by joejr2, Aug 15, 2019.
  1. joejr2
    Santa Fe,NM
    I took my bike out the other day and got a screw in the rear tire. Ouch ! It had less than
    1k on it. I plugged it, fired a can of fix-a-flat into it and got it home. I mount my own tires
    on a homemaid jig, "So" I thought "why not put a tube in it".
    It's a 130/90- 16" I'd be grateful to anyone who has info on what size/type of tube to order.
  2. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    If you match the profile and size a regular tube should fit. Why not take it off and just get it patched at a tire shop?
  3. XJ550H
    if you go with a tube pull out the plug and patch from inside with a patch or a mushroom shaped plug.
    fix a flat you have a clean up job a head of you.
    tubes are ok to use but the tube makes the tire run hotter (temp)
    Polock likes this.
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    While cleaning the chain on my xj550 I found a nail in the center of the tread on the back tire. It had been there awhile without deflating. Of course, pulling it out let the air out.
    I call a local motorcycle shop and asked if I could fix the tire with a plug like you do car tires. The answer was, "Yes, you can, but only to drive it to a place to get a new tire mounted."
    It matched my thoughts, I'm not sure I would trust my life to a motorcycle tire that has been patched. Maybe using a tube would be different.
  5. k-moe
    I just use a plug and call it good, unless the sidewall is damaged (then it's time for a new tire).
    Fix a Flat makes a mess and usually isn't a permanent repair. A good plug repair is easy, and can be considered permanant so long as you add it to your normal pre-ride check routine.
    The only issue with running a tube is making sure that it's sized right so it dosen't rub or pinch. Either will cause the tube to fail, and they can fail quite spectacularly.
  6. joejr2
    Santa Fe,NM
    So the tube would also be ID'd as 130/90-16 ?
  7. joejr2
    Santa Fe,NM
    Meant to say ID'd as 130/90-16
  8. mlew
    mlew Well-Known Member
    Apex, NC
  9. cgutz
    SE South Dakota
    Oh well, the rear tire I had, while good tread, was 6 years old, so replacing was in order
  10. Polock
    i've run the sticky plugs in tires till the tire was shot. the best way would be a patch on the inside.
    after a few hundred miles, can't even find the plug. i'd rather plug or patch than do a tube
  11. joejr2
    Santa Fe,NM
    Dude, You made my day
  12. Polock
    since you do your own tires, you've seen the corrosion that can start in the rim. i don't know if that fix-a-flat will help or hurt or not matter with that.
