Installing Tach Cable
Discussion in 'XJ Technical Chat' started by MichaelDD, Jun 23, 2016.
  1. MichaelDD
    MichaelDD Member
    milwaukee, wi
    Warning: mechanical newbie
    I searched for a thread that might have this insight but didn't find anything so hear goes:
    RPM gauge didn't work, tach cable was severed. So I bought a new one.
    I'm having a heck of a time getting the thing installed though. It made sense to me to start at the top by the gauge and stick it in, screw the top (or bottom) on, and then work at the bottom
    The problem I'm running into is that I can't seem to get enough slack at the bottom to stick into the little hole square hole and keep it in there. It's like I can't get enough pressure to get the thing in the hole at the bottom. What am I missing?
    Alan63 likes this.
    is it the full assembly? or inner cable?
    start at the bottom install on motor run it up in front of brake line union up to tach
    my cables are long and bulge out over front fender
    edit to routing
    Jetfixer likes this.
  3. k-moe
    Chack how you have it routed, and that you have the correct length of cable.
  4. MichaelDD
    MichaelDD Member
    milwaukee, wi
    It's the full assembly, it's maybe an inch or two longer than the OEM.
    So do I need to remove the allen bolt at the bottom by the motor first to get the inner cable to stay in? I can't seem to just shove it in the little hole without it coming out when I put the inner cable in the gauge up top.
  5. XJ550H
    22-1/2 inch cable on 2 bikes seca, maxim with an angled ferrul at motor
    24 " on maxim with stright connector bulges out over fender should be a little shorter but does not have angle on ferrel
    MichaelDD likes this.
  6. XJ550H
    could be there is a piece of cable stuck in the motor side the cable threads on to the motor just like the tach.
  7. MichaelDD
    MichaelDD Member
    milwaukee, wi
    Perfect, no stuck piece, just couldn't get the sucker in there. Thank you!
  8. XJ550H
    could be the ferrel came off the end of the cable and is stuck in the housing on the motor
