Instrument cluster odometer resetting
Discussion in 'XJ Technical Chat' started by Steveb, Aug 6, 2018.
  1. Steveb
    Steveb Member
    Ireland
    Hey people my trip odometer keeps resetting.
    It's an 82 xj750 D2
    I looking for a pic of the wire I would need to check for breaks that keeps the instrument cluster from resetting when you turn off the ignition . if someone can point in right direction.
    Literally just want to check the wire for breaks start at the easiest option checking the wire and then strip the fairing if not that
  2. Jetfixer
    Sounds like you do not have a stock speedo , does yours have a digital readout? My cluster the trip odometer is mechanical with a reset knob. Pictures might help. Cheers
    Steveb likes this.
  3. Steveb
    Steveb Member
    Ireland
    Will try get pics up tomorrow the d2 came digital in 82 all digital dash
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I have zero experience with that but have you found a wiring diagram? I would see if there is a wire that is constantly hot for the dash. If not, then you’ll need to pull the cluster apart and see if there is a battery or cap in there for memory.
    Maybe someone with more knowledge of that model will jump in but that’s where I would start if I had one and nothing to start with.
    Rooster53 likes this.
  5. Rooster53
    Steveb likes this.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looks like this?
    Steveb likes this.
  7. k-moe
    Ya. JDM only.
    Contact member Yu Tanaka. He is from (and is in) Japan, and should have access to the information that you need.
    hogfiddles likes this.
  8. hogfiddles
  9. Rooster53
    Well since you have the only manual in existence in the states maybe you can help the OP by looking at the electrical diagram to see if there is unswitched power to the instrument cluster.
    Steveb likes this.
  10. hogfiddles
    I'll see if I can____
  11. k-moe
    The FSM usually does not include schematics for individual component circuitry.
  12. hogfiddles
    Here's what I THINK you need....
    Ist pic is of the dash with what I THINK is the word/characters for what you need to match up somewhere in 2nd pic.
    I don't read or speak Japanese, so other than being able to give you the pics, I can't tell you anything other than it's really cool to look at this manual :)
    Steveb likes this.
  13. Rooster53
    Thanks to hogfiddles and the diagram you can see the output of the main fuse has a wire that goes to a 6 pin connector on the CMS. That should be the one that keeps the cluster from resetting for the trip meter, clock, etc. Unfortunately, you still need an interpreter to determine the wire color, but just finding that connector and probing for a unswitched 12V power should suffice to rule out the wiring.
    Steveb and hogfiddles like this.
  14. Steveb
    Steveb Member
    Ireland
    Th
    Much appreciated for the pic I know that as rear as the bike. Funny enough I charged up the battery on a different issue and the odometer and clock are now working again. No reset when turn off the bike
  15. Steveb
    Steveb Member
    Ireland
    very much appreciated for the replies lads charging my battery seem to bring the trip odometer and clock working again .would that be maybe the reg/rectify be failing
  16. Steveb
    Steveb Member
    Ireland
    Hey hogfiddles that's my bike in the add you found lol was going swap/sell it but it kinda grows on you. It was only released for the domestic Japanese market originally fuel injection but very unreliable now running Fazer 600 carbs
  17. Steveb
    Steveb Member
    Ireland
    Yep that's it fairly advanced set up for 82
  18. Steveb
    Steveb Member
    Ireland
    Thanks jay actually charged battery and everything came back to life odo and clock working again
  19. Steveb
    Steveb Member
    Ireland
  20. Rooster53
    Well that turned out to be easy, we should have suggested checking battery voltage.
    And yes you should check out the charging system and the battery. With a fully charged battery (12.8V) and meter leads placed across the battery you should get in the neighborhood of 14.5V +/- .3 volts at 2K rpm and up - assuming the 750 D2 charging system would be similar to the others of this era.
  21. Steveb
    Steveb Member
    Ireland
    The battery is 6 months old it's a yusa I thinking it could be reg/rectify it's the 1982 original I think all Japanese writing on front of it
  22. Steveb
    Steveb Member
    Ireland
    So I am back again the problem resurfaces once I let the bike sit for a day or two the clock and odometer resetting again. It worked great for few days then let it up for day or two and back to square one
  23. hogfiddles
    Does the bike start normally though?
  24. k-moe
    Is there a battery for the trip odometer memory? If not, would it be difficult to wire one in?
  25. Steveb
    Steveb Member
    Ireland
    Yeah starts on the button no problems there and the light gets brighter as you rev the bike in neutral. It has 12 or so amps sitting in the bike and goes up to 13.5 under load of 2k revs I probably just being picky TBF. Just a a mpg nerd I like to know what distance I am doing don't care bout the clock it's the trip odometer I want lol
  26. Steveb
    Steveb Member
    Ireland
    For lads here on forum no me yes I have biked for 13 straight years and learned I bad with spanners
  27. hogfiddles
    You mean VOLTS
  28. Steveb
    Steveb Member
    Ireland
    Sorry yes volts lol for its age everything else runs smooth I can. Get over it but thank you everyone for the pics the suggestion and problem solving
