Intake Boots
Discussion in 'XJ Technical Chat' started by AWHH, Jan 8, 2022.
  1. AWHH
    AWHH New Member
    Port Coquitlam,BC Canada
    Hi All, I’m new to working on bikes and was wondering if someone could help me. Could be a dumb question so bear with me.
    I have an 80 xj650 and one of my intake manifold boots needs to be replaced. I’m having trouble sourcing a replacement locally and online they all say for 81.
    Will an 81 fit on the 80?
    Thanks for the help!
  2. Dan Gardner
    Minneapolis, MN
    Yes, they should.
    Here's a trick - there are several parts sites, in this case Partzilla, where you can look up parts and part numbers. Then when you click on a part, it will tell you what other bikes it goes on, so it makes it easy to confirm that it is the same part on both: https://www.partzilla.com/catalog/yamaha/motorcycle/1980/xj650-xj650g/intake
    Another recommendation: **highly recommended**: Get your stuff from Len at xj4ever.com - a.k.a @chacal. This will eliminate the guesswork. http://xj4ever.com/catalog/c.html
  3. AWHH
    AWHH New Member
    Thanks, I will definitely look into this!
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    What bike exactly? Got a pic of the motor? The 650s had a couple different layouts for intakes and can vary in the same year (82 Maxim 650 with YICS vs. 82 Seca 650 No YICS). It should be the one Dan shared but we’ve seen 650s swapped from one style to another so a pic would help.
  5. AWHH
    AWHH New Member
  6. AWHH
    AWHH New Member
    I’m not sure exactly what model of 650.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    It’s a Maxim with the correct style engine.
  8. AWHH
    AWHH New Member
    Thanks for your help! It’s much appreciated.
  9. jayrodoh
    jayrodoh YimYam
    Cleveland
    XJ650G to be more specific.
  10. hogfiddles
    1980 and 1981 xj650 maxims (as shown) all are non-YICS (as shown), so all 8 boots are the same.
