intake manifold hose to the petcock?
Discussion in 'XJ Technical Chat' started by thunder1295, Jul 22, 2012.
  1. thunder1295
    thunder1295 New Member
    Cambridge Ontario
    I have an 83 XJ 750 R and the ? i have is what and for what reason is there a hose running off 1 of the intake manifolds going back to the gas tank petcock, what is the purpose of this hose and what does it do and do you need it running back to the gas tank.
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    You have a vac operated petcock, the hose provides vac to the petcock so fuel will flow when set to on or res. Prime flows regardless of vac.
  3. thunder1295
    Cambridge Ontario
    Thxs, that explains it..
  4. tatesmith
    tatesmith New Member
    ok where does it connect to though i have the same thing but cant figure out where to hook it up among other issues in having with my fuel system.
  5. bigfitz52
    There should be two hoses coming off the petcock (fuel valve.)
    The larger one is the fuel line and goes to the carbs.
    The smaller one is the vacuum line and it should go to your #3 intake manifold's vacuum spigot.
    If you replace the vacuum line be sure to use real vacuum line; other types may cave in on themselves under vacuum when they get hot.
  6. Sabre
    Sabre Member
    Lansing, MI
    What's the difference between having it on #3 and having it on any of the others?
  7. Buffalony
    Buffalony Member
    Corning NY
    Good question. I'd like to know the answer too.
    My best guess is that it has something to do with ignition timing.
  8. bigfitz52
    As far as I know, it was simple "expedience." (Nothing to do with ign timing, for sure.)
    On the 550s, it goes to #2.
    On the 650/750, it goes to #3.
    I know that on the later 600s, the #2 carb alone had a couple of different settings, possibly to compensate for that. But I cannot say for sure.
  9. Sabre
    Sabre Member
    Lansing, MI
    Interesting. I just moved mine from #3 to #2 because I suspected a vacuum leak around the #3 manifold, which I believe I've fixed now. I'd like to keep the hose on #2, though.
  10. bigfitz52
    Should present no issues whatsoever.
