Interchangeable Exhaust headers
Discussion in 'XJ Technical Chat' started by sybe, Sep 30, 2018.
  1. sybe
    sybe Active Member
    NYC - Brooklyn
    While unbolting header #2 my flange split in half, the pipe is in great condition minus the flange. Is there a way to remove the random bolt at the bottom of the header pipe and put on a replacement flange? Figured i ask before i attempt it and break something.
    In case i cant fix it, does anyone know what exhaust headers will fit an 82 xj650 maxim? other bikes makes, models etc...
    sybe likes this.
  3. sybe
    sybe Active Member
    NYC - Brooklyn
  4. sybe
    sybe Active Member
    NYC - Brooklyn
    do you know if header pipe #2 and #3 are the same shape and length?
  5. XJ550H
    I think the differance between 2 and 3 is the test port angle
  6. chacal
    I believe all 4 pipes are different in their overall bend angles, i.e. #1 is a mirror opposite of #4, and #2 is a mirror-opposite of #3. You might be able to jam a #2 pipe in place of the #3 pipe (and same for #1/#4) but you may end up with an exhaust leak at the bottom of the pipe, where it goes into the "collector" (I realize that the 650 Maxim doesn't have a traditional "collector", but the same thought applies).
  7. Polock
