Interesting discovery. XJ650 Hitachi carbs on my 85 Maxim x
Discussion in 'XJ Technical Chat' started by jayo84, Jun 18, 2013.
  1. jayo84
    jayo84 Member
    Irwin PA
    What will this mean as far as getting it to run? I paid 800 for this bike that was said to be running great until put into storage for 2 years. And I am almost done re assembling. I noticed also, I have a 110 main jet and 40 pilot jet.
  2. bigfitz52
    So they're HSC32s? Not even 33s (which would be off a 750?) The jetting says "650" too though.
    You're supposed to have Mikuni BS33s. I would look for a correct set of carbs; there will be slide/needle differences not just jetting. And since it's a 20-valve X-motor, I don't know if you could get the too-small Hitachis to work well enough to provide the performance that motor is capable of.
  3. jayo84
    jayo84 Member
    Irwin PA
    Re: Interesting discovery. XJ650 Hitachi carbs on my 85 Maxi
    Well, thats upsetting. I am not sure if they are 650 or 750's for sure, but I just seen a diagram for the 650, and mine seems to match.
    I actually got it started for the first time last night. I am impresses how it revs quick, but I discovered more issues. I have a stumble down low, and then it hangs before it drops to idle. Doesnt idle too bad. didnt need the choke to start either.
    I can hear air sucking on intake manifold boot #1 and i felt around while it ran, and the air noise could be squelched if I applied pressure to part of the boot. I assume this is the main cause for problems.
    Anything else to look at based on this activity?
  4. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    is the boot cracked?. also the stumble + hang could be certainly related to the wrong carbs....
  5. jayo84
    jayo84 Member
    Irwin PA
    I am going to assume the boot is cracked, its on the underside of the boot where I can not see. I was also informed that not being synced would cause stumble and or hang
  6. jmilliken
    Dillsburg, PA
    yea... it could be lots of stuff.... and Fitz is right.... if you do indeed have the wrong carbs, you aren't gonna get what you should out of that bike.
  7. jayo84
    jayo84 Member
    Irwin PA
    I assume I will not get max from this bike. At this point I may just want it to run ok and sell it. It should be some what desirable as it has the high backrest and highway bars with pegs. I know I will struggle to find nice mikuni carbs, there none really on ebay, and the ones that are look terrible.
  8. Ari_Gold
    Ari_Gold New Member
    Central NC
    Have you correctly inspect the vin on your bike maybe it is a 750?
  9. RickCoMatic
    Don't be dismayed by the look.
    Filthy Carbs will clean-up nicely with a thorough cleaning.
  10. jmilliken
    Dillsburg, PA
    yea... you follow rick's carb cleaning guide.... and they will look brand new. OR YOU CAN GIVE IT TO ME :)
