Is my shifter arm worn?
Discussion in 'XJ Technical Chat' started by Millzattc, Jan 18, 2020.
  1. Millzattc
    Millzattc New Member
    TN
    Having trouble shifting into first (back arm is slipping off peg) and once into first it is hard to get back out. Could this be caused by a worn shifter arm, bad springs, or both?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    those symptoms are more usually caused by either a badly adjusted clutch or cable , or a bent or binding shifter shaft.
    remove the shifter cover ,and see if the lever moves more freely.
    those "dogs" don't look too bad. but-------
    what bike is it?
  3. Millzattc
    TN
    85 Maxim xj700 air cooled. I have the whole shifter arm/shifter shaft and mechanics out at the moment.
  4. Millzattc
    TN
    Anyone else have a suggestion? Does everything look like it is in the correct position in the picture? If so what is causing it to shift hard into first and the arm to slip off the star drum? If needed I can try to post a video.
  5. Polock
    that arm looks ok. it's been awhile all i remember is it has one long pin in that cam wheel and it needs to be in the right place
    there's some other springs in that mechanism, you got all of them
  6. Millzattc
    TN
    All my springs are here I believe and I haven't taken the star wheel apart so the long pin should be in the correct place.
    Ok feeling like a rookie... must have had a pin fall out and I placed it in the wrong place. After SEVERAL attempts at moving pins i can get all gears now.....:mad:
