Is this site still active? New xj owner need help
Discussion in 'XJ Technical Chat' started by BigDub27, Aug 27, 2015.
  1. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    I got an 82 xj750 turned bobber need help with carbs. Trying to get set close without synchro. Carbs puffing back out while starting, issue?
    yes it is still very active
    did you do a bench synch on the carbs it is a simple process.
    there is also a few threads on making a carb sync tool for less than 10.00
    have you cleaned or rebuilt your carbs?
    did you set the pilot/idle mixture screws to 2-1/2 turns out from lightly seated?
    air pods and stright pipes i see this is going to make things harder for you, there is a thread in the mods forum about people who have had success on doing this you should read that thread.
    have you done a compression test on the motor, and checked your valve clearances?
    these are things you need to do to help get your diaginosis.
  3. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    Do all 4 have to be done at one time? The guy I got it from had parts to put back together the carbs. Unsure whether they were knew or not. I will set again at that right now and try
  4. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    Compression seems good. I've riden it twice around my neighbor. Pulled like crazy. I think more than my 929rr I traded for it. Yea pods and straight, freaking loud
  5. XJ550H
    what you do for a bench sync is use the idle adjuster knob to open buttery flies, use a tiny drill bit #60 to #80 or piece of wire or a strip of bussniess card.
    slip it into carb 3 (from left to right) then back off the Idle knob untill you feel it drag, then on carb 4 turn adjuster screw on throttle shaft to open butter fly insert objec into that carb and adjust to the same drag. then do carb #1 to carb # 2 in the same fastion. the final step is doing carb set 1&2 to carb set 3&4 then all will be set to same position.
  6. XJ550H
  7. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    So it goes( looking at carbs on motor)
    4 3 2 1
    Or
    1 2 3 4
  8. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    That's the problem it's hard to get started. Takes bout an hour to get started. Once the motor is warm it usually fires. Cold start is no go lol. Plus the person rigged up starting on this. Has toggle switch, pull switch and then you push the push button
  9. XJ550H
    sit on bike left side as you sit is 1 then 2 then 3 and carb 4 is the far right
  10. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    Made a similar contraption for my old vstar
  11. XJ550H
    what kind of carbs MIKUNI or Hitachi
    if MIKUNI here is a rebuild pdf it is good reading
    http://www.mtsac.edu/~cliff/storage/gs/Mikuni_BS-CV_Carburetor_Rebuild_Tutorial.pdf
    there is also a Hitachi link some where here
    I will tell you now if carbs are not clean inside you will have a hard time and progressivly harder time starting bike.
    we have a few carb experts here but probaly at work or out riding you will be hearing from them with better advice than I can give you,
  12. XJ550H
    sounds like you have an issue with your enrichment circuit (choke) in the carbs
    motor starts on the enrichment circuit then pilot circuit takes over for the first 2k or so rpm then the main jets kick in.
    link of the inside of your carbs will show you things
    http://www.xj4ever.com/inside your carbs.pdf
    you will also want to visit this link
    http://www.xjbikes.com/forums/forums/xj4ever-supporting-vendor.23/
    many good carb threads
    also add your full bike type to your profile it will help us all. i gotta go its riding time
  13. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    Hitachi carbs. I'm taking them off and doing the bench sync as you suggested. Sorry for the double post
  14. hogfiddles
    Back to the original question:
    Have the carbs been CLEANED THOROUGHLY??
    Since you have pods, has it been re-jetted?
    Have your valve clearances been adjusted to be in spec?
  15. BigDub27
    BigDub27 New Member
    Mt Pleasant, SC
    Cleaned yes. As far as jets I don't know if they have been or not. Carbs were in pieces when I got it. So had to put together with kit he had. And I haven't messed with the valves
  16. hogfiddles
    EXACTLY HOW did you clean your carbs?
    When carbs are CLEAN, and valves are in spec, the bike should start up at the touch of the button. Heck, when the carbs are spot-on, it should start almost instantly even if the valves aren't dead-on in-spec. My 700 is waaay overdue for a check, and it starts instantly any time every time.
  17. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Nothin sweeter than a finely tuned XJ bike. Set the choke and just bump the start switch, let it warm up and hit the road.
    Check your valves, pull the carbs, bench sync and wet set your floats. And while you have the float bowls off clean those enrichment jets out in the bottom of the float bowls. If its tuned right it should pop right off and run on all 4 evenly.
  18. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    http://www.xjbikes.com/forums/threads/success-stories-of-pods-and-4-into-1-exhaust.29381/
    See that Hoggfiddles guy above? He's the man. Listen to him, have happy mo-bike!
    He comes off as a bit cranky, but it's only cuz he's mastered the carb cleaning job, and everyone else is in Kindergarten. He just wants us to catch up.
    wgul and XJ550H like this.
  19. chuckle
    chuckle New Member
    erith
    My xj900f starts ,but fuel poor's out of one of the large tubes their are 2 of them . I have no idea why , lost half a tank of fuel , Any ideas ,
  20. hogfiddles
    Those extra tubes are overflow tubes. So, most likely you have a float sticking open
    quebecois59 likes this.
  21. Brandon Amundson
    Brandon Amundson New Member
    portland, ME
    I am about to start chopping my yamaha xj700 maxim. My plans are to lower it (maybe struts), cut the fender off, new seat and bars, and make it sound loud. Any thoughts or suggestions. I don't really know where to start.
