It's easier to ask than search...petcock leak?
Discussion in 'XJ Technical Chat' started by jeffcoslacker, Oct 2, 2010.
  1. jeffcoslacker
    jeffcoslacker Member
    SW MO
    My '83 XJ650's petcock leaks slightly on the reserve position when not running.
    I would imagine there's a rebuild going to be in my future?
    What is actually happening?
    For now, screw it, I don't run to reserve much.
  2. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    I changed to the manual petcock from XJ4ever just have to remember to turn on & off
  3. Ravenz07
    Ravenz07 Member
    I wouldnt ignore a problem. Chances are its just the beginning.
    Fitz has saved me a number of times on here with his advice. Thanks to him I was able to fix my leaky petcock (and a lot of other things) for my ongoing project. He was nice enough to make a rebuild tutorial for these petcocks, just make sure to do everything he says in the tutorial, no shortcuts!!!
    http://www.xjbikes.com/Forums/viewtopic ... build.html
    Message Chacal on this site to get a rebuild kit.
  4. bigfitz52
    Thank you, I appreciate the recognition, happy to help. You said something worth reiterating:
    THIS is probably the most important "XJ Law" of all! It applies to petcocks, carbs, brakes; just about anything on these bikes you're trying to set right.
    Actually, it applies to the whole process.
  5. Cmccully04
    Cmccully04 Member
    State College, PA
    +1 on the manual petcock from chacal. I got one and love it.
  6. MiCarl
    Since it apparently doesn't leak in the "ON" position the vacuum valve will be good.
    Behind the selector lever there is a seal with five holes in it. After 25 years or so that seal wears out. A new one is about $10 from the dealer and it's an easy fix. Just drain the tank and pull the two screws that hold the selector retaining ring on.
  7. schooter
    haha MiCarl, are you implying there IS a shorcut?
  8. Ravenz07
    Ravenz07 Member
    He lies!!! He will feel the wrath of the motorcycle gods!!!
  9. quikcobra
    quikcobra Member
    Orlando Fl.
    The link above was great, So rebuild that thing and let us know how it goes.
  10. MiCarl
    No, not shortcut. Just not fixing extra stuff that ain't broke.
