I've got a screw loose
Discussion in 'XJ Technical Chat' started by wizard, May 8, 2008.
  1. wizard
    Is it possible to get the glass off the tacho' ? one of the small screws is floating about in there.--1980 xj650 :?:
  2. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
  3. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    If it's a sealed one that doesn't unscrew you have to cut the ring around the front and pry the glass off. It's possible to pry up the ridge around the inside of the top cover all the way around but I found it easier to just cut it at the bottom and pull it off. Then you can glue it back on with some RTV silicon rubber.
  4. wizard
    Hi Jim, what a ripper site, unfortunately the models differ over here and you have to look at the xs to see my gauges and the whole thing comes as an assembly. the us model has the 2 glasses and rims joined together with a flat on one side.
  5. wizard
    yeh, i recon that's what i'll have to do. steve.
  6. shamus
    shamus Member
    i got mine off by loosening the ridge...it was a bitch to get it back on neatly though....
  7. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    Well, that just stinks. I 'm using a gauge cluster from a U.S. model 1980 xj650 on my 1981 xj550r and it was a cinch for me to unscrwew and pull the covers off to repaint the dials.
    I guess you're stuck having to use ArizonaSteve's or Shamu's suggestions.
  8. wizard
    yeh, i've nailed it, uncrimped the rim & then re-crimped it.
    it takes the patience of a saint not to screw it up.
