I've searched high and low but no answers on this XJ carb problem:
Discussion in 'XJ Technical Chat' started by Vince Cmela, Jul 26, 2017.
  1. Vince Cmela
    Vince Cmela New Member
    Selkirk MB
    Hi All, first post...1982 Yamaha XJ750J Maxim . Carb rebuild. So I go to remove the first main jet and it moves but real sticky...and actually keeps on spinning but no progress. I eventually identify that the emulsion tube is spinning with it and it just aint gonna come out. It's actually quite loose now (the emulsion tube and jet) so this jet will not be coming out. I moved to the other jets and immediately verified that the emulsion tube for each starts spinning immediately when I start loosening the main jet. Now I'm thinking the only solution will be to carefully, surgically grind off the main jet until I can release the tube and then see about drilling out the jet remnants and hopefully save the tube. Any thoughts on a better solution or similar experiences?
  2. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    I suggest waiting to do anything that will be permanent until one there is a response from one of the folks here that regularly works on carbs. They don't typically need anything ground out.
    Nuch likes this.
  3. Vince Cmela
    Selkirk MB
    Will do. I'm investigating parts ordering for now. Thanks!
    Remove the slides if you have not done so already.
    At this point I am going to sound like my grandfather, so bare with me.
    Whittle you a stick.
    Make it have a cone shape at one end so it can fit snugly into the top of the emulsion tube.
    USe that to hold th emulsion tube as you unscrew the jet.
    It is wise to apply penetrating oil (not WD-40) to the threads of the jet to help the threads free up.
    You may have to run the jet in and out a bit to help clear debris from the threads before it will back out all the way.
  5. Vince Cmela
    Selkirk MB
    Thanks, I'll give it a go and let you know. I have this strange feeling the tightness of these jets is a combination of being overtightened on a previous clean and potentially some threadlock applied. They are super snug but maybe your trick'll work. Thanks again.
  6. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    How many people these days would have to Google 'whittle', I wonder?
    Wintersdark and Jetfixer like this.
  7. Vince Cmela
    Selkirk MB
    Quite awhot, I would guess.
    Got my carbs in the freezer now. Hoping the press fit of the tubes will tighten up that way and help hold them in place. Found some straw to chew on while I prep the wood.
    Jetfixer, Chitwood and Stumplifter like this.
  8. Toomanybikes
    Tsawwassen bc
    A chopstick sometimes works to hold tube while you unscrew jet
    Jetfixer likes this.
  9. Vince Cmela
    Selkirk MB
    Tried the carved stick and though it might have been viable if at least the jets had started to loosen up it appears that actually "breaking them loose" from those tubes just wasn't gonna happen so... out came the hand held grinder and off came the heads of the jets. It actually worked great. Once the head was gone the tube dropped out and with a bit of torch and some pliers the "friggin" jet remainder easily backed out. I'll order some fresh jets and all should be good. Now I can also become part of XJ lore: as in "I know a guy that rebuilt his carbs with a grinder". Try offering that advice to anybody.
    So the next question is...is there a specific technique for the reinstall of these tubes once I get the jets? I foresee being unable to tighten them without the same spinning taking place?
  10. TheCrazyGnat
    Central PA
    In my (limited) experience, the fact that they are pulling each other together works just fine to keep them from spinning.
  11. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Did you find out why they were so tight and the emulsion tube turning on you ?
    Was there gunk or threadlocker on them ?
    Just make sure you don't use any on the re-assembly
    Stumplifter likes this.
  12. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Put the grinder in reverse.
    Get your replacement jets and rebuild parts from XJ4EVER read this: http://www.xj4ever.com/inside your carbs.pdf and then do this: http://xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    Inquiring minds want to know:
    Exactly how did you grind the heads off? No "oops" and marring of the carb throat?
  13. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    K-moe is right but if you use the foam paint brushes....the ones with wooden handles and break the foam end off, the wood is the perfect softness for the job. I've been doing it this way for year and it works 90+% of the time. Take the wooden handle and using a ball peen or other light hammer, hammer the wooden dowel right over the shroud(use a handle-dowel that is larger that the shroud)...it will sink into the soft wood with deflecting and it's large surface area will actually help hold that end while you apply a tool the the jet to remove it. It helps if you heat the top(shroud side) with a torch at low heat while applying a lube such as Kroil to the jet threads. Capillary attraction will cause the lube to seek the source of the heat drawing it down onto the threads......patience and judicious use of force will prevail....does every time!
    jeff
    Wintersdark and Stumplifter like this.
  14. Vince Cmela
    Selkirk MB
    I found nothing really. No evidence of threadlocker. I am pretty boggled as to how all of my main Jets were doing this and yet it seems evident that this hasn't really happened to anyone out there before? I am going to mark it down as simply a case of the main Jets being installed way too tight and probably never coming out for a very long time.
  15. Vince Cmela
    Selkirk MB
  16. Vince Cmela
    Selkirk MB
    Unfortunately the grinder does not have a reverse setting so I will be stuck doing the job with a screwdriver. Unconventional but hopefully I can get the job done.
    TheCrazyGnat likes this.
  17. Vince Cmela
    Selkirk MB
  18. Vince Cmela
    Selkirk MB
    I actually had some dowel stock which I whittled to a shape that lined up pretty much as you described. Try as I might I could not keep the tube from spinning when I loosened the jet. I didn't apply heat or a lubricant on the jet or bowl body which may have been the solution.
  19. hogfiddles
    I just jam a pencil in the tube when I've had to do this
  20. Lightcs1776
    Upstate NY
    Oh, I sure hope it isn't many people. I can't be that old, can I?
  21. Jasonh
    Jasonh '81 XJ750 Seca
    Toronto, Ontario
  22. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    But not as many as would have to Google"awhot":p
  23. Polock
    was there a copper washer under the jets?
    hogfiddles likes this.
  24. JeffK
    "was there a copper washer under the jets?"
    Probably not but I have seen some so entrusted with thick lacquer that they take a bit to free up!
    If the dowel is large enough, the shroud should embed into it so it can't possibly spin.....
    jeff
  25. Vince Cmela
    Selkirk MB
    There was copper washers under all four main Jets. They were lacquered up a wee bit but are now destroyed from my grinding efforts. I really can't explain better how those Jets were so incredibly difficult to remove even with the dowel pressed firmly against the underside of the tube outlet. I am now ordering parts from XJ forever
  26. hogfiddles
    Most likely a meat-fisted PO
    Toomanybikes and Vince Cmela like this.
  27. Toomanybikes
    Tsawwassen bc
    Isn't it called "ham- fisted"
  28. hogfiddles
    Ham-fisted....meat-headed---about the same thing, isn't it? Lol
    Toomanybikes likes this.
  29. Toomanybikes
    Tsawwassen bc
    I think on this website "bacon-fisted" would be appropriate.
    Cause we like Baaaaacon
    Lightcs1776 and Stumplifter like this.
  30. MattiThundrrr
    Bacon-fisted: when Matti runs out of room on his plate at the breakfast buffet.
    Also see: sausage fingers.
  31. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    They took my whittling knife at the airport.
  32. k-moe
    Some nice security screener in Costa Rica has my Leatheman. Remember kids, always take you knife out of your daypack, and put it back into the checked luggage, before heading to the airport.
  33. MattiThundrrr
    Been Franklin:
    "Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety."
    TheCrazyGnat and k-moe like this.
  34. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Several years ago, my wife and I were an hour from heading to the airport for a trip. My adult daughter suggested my wife go through her bag to get rid of unnecessary weight - she usually has a kitchen sink, an anvil or two, etc. in her purse.
    In the bottom of her purse she found...a box cutter!!!! Unbelievable, can you imagine how long that would have held us up for questioning by TSA?
  35. Toomanybikes
    Tsawwassen bc
    Can you say "Cavity Search "
    cgutz likes this.
  36. XJcook
    XJcook New Member
    Raleigh, NC
    I must be one of those - meat/ bacon fist guys. I rebuilt my carbs last winter, and I remember making sure the jets were GOOD and TIGHT.
    Now I might be in for a surprise when I return :--(
