Japanese Screwdrivers in Canada
Discussion in 'XJ Technical Chat' started by Drew, Aug 18, 2015.
  1. Drew
    Drew New Member
    Cambridge Ontario
    Hi All,
    I'm trying to find a set of JIS (Japanese Industrial Standard) screwdrivers in Canada with no luck. I've tried the usual places Canadian Tire, Princess Auto, Royal Distributing with no luck. Does anyone know where I can finds them?
    Thanks,
    Drew
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Online.
    Ebay or any type of major tool distributor (grainger, MSC, etc.)
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Email Len at info@xj4ever and he will hook you up.
    Stumplifter likes this.
  4. XJ550H
    i found that the 1-1/2 inch long dry wall screw bits worked well, also electronics screw drivers are jis mostly.
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I took a regular philps screw driver and ground the tip flat, works well.
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Here's a picture to help with lostboy's suggestion:
    You just need to grind off that section where the phillips is angled to 19 degrees. Not exactly JIS because the phillips is still curvier in the cuts, but a decent substitute
    lostboy and Stumplifter like this.
  7. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Here's the tip of the one I use for butterfly screws:
    Part of a set of a couple screwdrivers that I modified a number of years ago specifically for my XJ:
