jet sizes from stock 82 xj750 carbs?
Discussion in 'XJ Technical Chat' started by BlackSpanker, May 17, 2010.
  1. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    I dont know if the idiotic PO put diff jets in there, he scored them up badly with pipe cleaners. If someone could list the jet sizes that would be much appreciated thanks
  2. chacal
    XJ750 Models:
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-13
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
    Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less:
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca Canadian models
    Carb Series: HSC32
    Carb Model ID: 15T00 (Maxim, Midnight Maxim)
    Carb Model ID: 5H200 (Seca)
    Pilot FUEL Jet Size: #43
    Pilot AIR Jet Size: #195
    Main jet NEEDLE ID: #Y-14
    Years & Models: 1981-4 XJ750 11M UK/Europe Seca models
    Carb Series: HSC32
    Carb Model ID: 5N100
    AIR COMPENSATOR Jet Size: unknown if used.
    Romandos and Strannik191 like this.
  3. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    thanks this site is very helpful!
    Strannik191 likes this.
  4. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Be helpful back! Put your location in your profile (at least the country) and put your bike Model/Year/VIN code (my 750 seca is 5G2) in your signature. That way chacal doesn't have to post ALL the information he has (and he just about has it all).
  5. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    the dealer can only order these jets for me if I have the part numbers. Where can I get them. the dealer's book doesnt have the jet part numbers thanks
  6. skillet
    skillet Active Member
    SW TN
    Get 'em from chacal (the fellow that was so helpful :wink: decent prices and fast service)...
    skillet
  7. Strannik191
    Strannik191 New Member
    Russia
    Thanks a lot, this info is very useful. Do you know what kind of carb model belongs to 1981 XJ-750E made for the internal Japan market?
  8. chacal
    No longer available from Yamaha.
    Hitachi HSC32 series.
  9. Strannik191
    Russia
    Thanks!
