Just got the bike on the road
Discussion in 'Hangout Lounge' started by Mike Othmer, May 19, 2016.
  1. Mike Othmer
    Mike Othmer New Member
    Windsor Ontario Canada
    Well just got the bike all done today .Went to start it and after it sat it sounded like it was getting no fuel just crank over .got spark. Pumped fuel and then it came to life took a bit . What could be the problem? 1983 550 maxim xj
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    How long was it sitting / not running?
    Did you put the petcock on prime?
  3. Mike Othmer
    Only sat for a day and this all started when someone messed with the pet cock.
    Is there fuel in the tank? Is there fuel in the crankcase?
    Who messed with the petcock, and how?
  5. Mike Othmer
    The turned it off that's it .yes lists of fuel in tank full . Might be the vacuum line will check it out.will keep you updated thax
  6. k-moe
    There is no OFF on a vacuum operated petcock.
  7. chacal
    Well, actually there is, it's called turning the engine off............:)
    ecologito, ColoradoDan and k-moe like this.
