Just went to war trying to put my exhaust back on
Discussion in 'Hangout Lounge' started by Hotcakesman, Apr 30, 2014.
  1. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    gee.. I am so damned sore
    I sanded and painted my pipes with high heat paint
    wrapped my headers
    and put in new O-rings
    I never thought I would end up about in tears
    after 4 hours I got them on.. that is something I do not
    want to do for a long long time
    ended up having to go to the hardware store to buy some smaller
    nuts and lock washers to attach the exhausts on the back
    sorry if I am whining.. but I never thought something so
    simple would kick my butt so hard...
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    What was the issue? The pipes didn't want to go into the ports? Anti-seize is always your friend with exhaust...
  3. bigfitz52
    Go to the auto parts next time. Think "automotive grade" when working on your bike; it's a motor vehicle not a lawn mower. You don't get Grade 8 bolts at the hardware store.
  4. Polock
    pretty sure we don't have any 10.9 bolts on our bikes
  5. bigfitz52
    Nope. But we do have Grade 8 or equivalents, and the local hardware store doesn't. But there's a NAPA a whole block and a half away that does. And in my town, "Main Street" is only 3 blocks long (and our stoplight at the "4-corners" goes to blinking at 11:00pm.)
  6. Polock
    a grade 8 equivalent in metric is a 10.9
  7. Hotcakesman
    South Dakota
    The issue is when I had my exhaust taken apart
    to wrap the front headers I snugged them together
    too tight, so that there was millimeters of space
    with were the exhausts bolted onto the back place on the
    bracket
    with messing with exhaust wrap being super not fun to
    play with.. I just said eff it
    and bought smaller bolts.. they are super snug and not going anywhere
    I just never thought a small job would turn into such a pain
    ohh well live and learn
  8. hogfiddles
    Everything has to go into position with very loose fits so that you can turn, twist, rotate, slide, etc.... everything til it's all in position. THEN you tight everything up.
    Dave
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    mm of space? how? there s/b more than mm of space between the headers and the plant even when wrapped that would allow the rear bolts slop to align. what am I missing?
  10. Hotcakesman
    South Dakota
    well lesson learned
    loose first then tight.. like the reverse of the prom
  11. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Ours goes red blink at 9pm... :/ lol
  12. Kickaha
    New Zealand
    What is that for?
  13. hogfiddles
    Stop, look all ways to make sure it's clear, then safely proceed. Other times, you have to stop and wait til the solid red light turns green.
    We have some around here that will go to yellow blinking at certain times....... that means you don't have to stop unless there is through-traffic from the side, just proceed with caution .
    Dave
  14. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Oh, did you wrap the entire system pre-assembled? When I did mine, I wrapped the front four pipes individually, and then the H and baffles as a single unit. That way I could wiggle the front four into place, then snug up the H into place.
  15. MiGhost
    MiGhost Well-Known Member
    Since when ??
    ACE hardware, and Tractor Supply both carry grade 8, and even chrome.
    Grade 8 is not required for the muffler mount bolts. There is no need for structural strength hardware for that location.
    Grade 5/8.8 will work fine. The muffler cans will give way before the hardware.
    Ghost
  16. Hotcakesman
    South Dakota
    that was my mistake..
    oh well.. I got them on.. and I don't plan on taking them off for
    a long long time
