Keeping Time
Discussion in 'Hangout Lounge' started by redsix, Feb 20, 2012.
  1. redsix
    redsix Member
    Western Pennsylvania
    Do you guys keep time on your bikes? What do you use/where did you put it? I think I'd like a little clock somewhere.
  2. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I've been told told that the time spent on your bike is not charged against your "time on earth" clock.
    Other than that........I just look at my watch whenever I stop to refuel.
  3. gunnabuild1
    gunnabuild1 Member
    Got one in my Dash but thats not much help to you.Have used a cheap watch in the past just stuck on a suitable surface.
  4. redsix
    redsix Member
    Ranger- I'll buy that! :D
    Gunna- That's probably what I'll do. Get a cheapie and stick it on there.
  5. bigfitz52
    I used one of these, made by Formotion specifically for motorcycles:
    Mounted on the little "dashboard" below the instrument cluster:
  6. redsix
    redsix Member
    Wow, Fitz. That is perfect! Thanks!
  7. mtnbikecrazy55
    I wear a watch :D
  8. bigfitz52
    So do I. But I also wear proper protective gear (armored jacket, etc.,) that makes actually GETTING TO my watch in rush-hour traffic a bit impossible at times.
    I found the clock to be such a useful "farkle" I installed one on the other bike too.
  9. RickCoMatic
    That clock looks great.
    But, around here, ... you'd come out from the coffee shop and it'd be gone.
  10. mtnbikecrazy55
  11. dmccoach
    dmccoach Member
    NE PA
    Sorry, I ride to forget about time...
  12. redsix
    redsix Member
    I usually wear a watch, but Fitz it correct. Gloves make it hard to get to. I'll probably see about a cheap-o watch and go from there.
  13. bigfitz52
    C'mon. I work in downtown Detroit, where they (the Cass Corridor crackheads) regularly steal my "centerstand board" from a guarded parking lot.
    It doesn't just "snap" off and on as originally designed, trust me.
    I like the Formotion clocks because they're impervious to vibration, rain, etc., plus it looks like it "belongs" since the numbers on the face are nearly identical to the Yamaha instruments.
    I've had one for over four years now and the other for over three, and I still have both of them. I might also note they keep the most accurate time of anything in the house other than my wristwatch.
    Highly recommended.
  14. redsix
    redsix Member
    Fitz - Where did you buy yours from? I see several websites listed.
  15. dmccoach
    dmccoach Member
    NE PA
    http://www.amazon.com/Formotion-Referen ... 103&sr=8-1
    Does anybody really know what time it is?
    Does anybody really care?
    If so I can't imagine why
    We've all got time enough to cry
    And I was walking down the street one day
    A pretty lady looked at me and said
    Her diamond watch had stopped oh damn!
  16. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    When I get on the bike and go, I really don't care about the time! The longer it takes me to get there the better I like it!!!
  17. bigfitz52
    I commute on my XJs, so I pretty much have to care.
    There is no clock on the Norton.
  18. redsix
    redsix Member
    I commute on mine as well. And I've determined (from showing up late a few times) that I drive much slower on my bike than I do in my car. I have to leave earlier, and I would like to be able to tell how much time I can spend on my bike before it'll make me late. :D
  19. bigfitz52
    dmcoach busted me-- I got mine off Amazon as well. Not quite the same model as what he posted though.
    I figured out what I was looking for from the Formotion website; then started web-searching and ended up with Amazon.
    The one I used is the 72000 model, stick on: http://www.formotionproducts.com/SO%20Classic2.htm
    They have a wide variety of styles, though. Aluminum cases, white faces-- lots to choose from. Explore their site.
    I pitched their "self adhesive discs" (the foam was too thick) and used the same 3M automotive trim mounting tape I use for sidecover badges and --go figure-- automotive trim.
    I've had one of them for over 4 years now (new battery) and one for about three years; and I'm VERY pleased. I can testify that they are waterproof and vibration-resistant, and keep very accurate time. (Maybe it's that Citizen movement.) Granted, they're not super-cheap. But again, you get what you pay for and I'm very happy with this minor investment in quality equipment.
    Highly recommended.
  20. redsix
    redsix Member
    Once you stick, how much trouble is it to get it back off for a battery change?
  21. Altus
    Altus Active Member
    London, Ontario
    I do a lot of farkle shopping from Aerostitch -- great folks from Duluth Minnesota! :) I used to live just up the highway from them...
    They have it too
    Formotion Clock
  22. bigfitz52
    No more difficult than removing say, a sidecover badge. You simply wrap a length of heavy fishing line around it and slice thru the tape, then peel off the remnants. It's a minor PIA but you only need to do it every 3~4 years.
  23. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I just have a sun dial mounted on my tank! ;)
    But seriously, my clock is displayed on my radio.
