kenda / shinko tire choice
Discussion in 'XJ Technical Chat' started by Stormin, Mar 19, 2015.
  1. Stormin
    Stormin Member
    Poughkeepsie, NY
    Getting close to finishing the braking system, first things first, so now it's time to think about tire selection.
    I have been looking at the kenda tires. I'm doing this on a low budget, but want to be safe. No crazy corner carving yet, I'll be taking it easy for a while until i get the bike all sorted out, and this is my second bike.
    There is the:
    RetroActive.
    Challenger.
    Cruiser.
    Kruz.
    or maybe
    Shinko 230
    Is any one tire better than the other?
    Just looking for some direction before I order them.
    1981 xj650 Maxim.
    Norm.
  2. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    You may be limited to certain lines of tires based on sizes. I ended up buying spitfire s11's for my '80 650 max, but if you look up the intent and purpose for each tire you may find that some are more suited sporty high speed riding, while some are made for better rain characteristics, or wear or load capacity etc. If you read the info on all the different kenda tires you may be able to narrow it down
  3. Beekman
    Erin, Ontario
    For example, the challenger and the cruiser both say " not for high capacity bike" so if your bike is ivetly heavy or has full fairing and luggage or you do a lot of 2 up riding, you might stay away from those
  4. Beekman
    Erin, Ontario
    *overly
  5. Stormin
    Stormin Member
    Poughkeepsie, NY
    This is why I'm asking. This is the first time buying bike tires.
    No fairing. No luggage racks/boxes etc.
  6. Beekman
    Erin, Ontario
    Then you can probably use any of the kendas you want
  7. MiCarl
    I run Kenda Kruz on my Venture and on my wife's 750 Shadow. When her new V-STAR 650 needs shoes it'll get a set of the Kruz too. It's designed to be a cruiser tire but it behaves quite nicely on my 89 Venture, which is a sport tourer. I don't have any problems with it in the rain, but I don't ride aggressively when its wet. The only squirrely event I ever had was in a hard turn, heavy acceleration across a tar snake - the rear end kicked out a bit. I suspect the snake moved rather than the tire slipping and no tire can prevent that. I went with them on my Venture for 2 reasons: 1) It's the only tire that has the load rating I wanted without going to a premium tire. 2) I figured a nail or screw on the road might as well ruin an inexpensive tire as a pricey one. In my shop the Kruz is hands down the tire I sell the most of and only had one complaint - the customer thought they were noisy. We get decent life from them (12,000 miles or so on heavy cruisers).
    With a standard motorcycle (650 maxim is a standard) you could go with the Kruz or the Challenger if you think you'll be riding aggressively and want a sporty tire. The Retroactive is a newer tire that I haven't installed many of, but you might like that if you want something that looks more like the vintage of the motorcycle. Your 650 is light enough you don't have to worry about load index on any of the tires.
    Realistically there is not an unsafe tire you can buy from any manufacturer. They're all WAY better than the tires that were on it when it came out of the factory.
  8. FtUp
    FtUp Well-Known Member
    pacific northwest
    I am looking at the kenda retroactive or the shinko 230 tour master for my next set of tires. I like the look of the tour master better, but they both will fill my needs at a decent price.
    FU
  9. Stormin
    Stormin Member
    Poughkeepsie, NY
    Ok. And the shinko 230 are only $4 more for the set.
  10. Stormin
    Stormin Member
    Poughkeepsie, NY
    yes. I need to get the tires that came from the factory off the bike.
  11. FtUp
    pacific northwest
    at this point, those shoes are hard as nails and wouldn't grip sh*t. lol!
    FU
  12. Stormin
    Stormin Member
    Poughkeepsie, NY
    Front leaks down but the back still holds air. I won't use them for anything but to push it around the garage. A whole lot of dry rot cracks. But they only have 6000 miles on them.
  13. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    You should do some burnouts.
    I got a spare rim with an old tire that im saving for someday im bored.
    Ive used the challengers with no complaints.
  14. Stormin
    Stormin Member
    Poughkeepsie, NY
    Now there's an idea. .
    Now to get out of this horrible 80 degree weather and back to reality, and working in the cold garage. I hear it was 20 and snowing today at home.
    I'll order tires when I get home . And my caliper piston from Len should be there soon.
    jmilliken likes this.
  15. hogfiddles
    I use a lot of the Kenda challengers when I can't get my preferred Dunlop d404's. I've had no problems with them. That's also with a lot of 2-up on 650's and 700's.
    The Dunlop is a bit more expensive, but lasts longer and I feel like it sticks to the road better, I like it more, but the challenger has been just fine for me when either the d404 isn't in stock in the shop, or the dollars aren't in stock in the wallet.
    Dave Fox
  16. hogfiddles
    Make sure that you go easy for the first 100 mi or so to scrub mold release agents off of the new rubber, and take curves easy til they scrub the surface wide enough..... any new tire can be slippery for a little while.
  17. cutlass79500
    lawrenceville georgia
    I have a set of originals plenty of tread changing the front tomorrow shinko 230 i think see how they work out motorcycle super store had a sale about a month ago .
  18. Polock
    i use kenda challenger and don't even think about it anymore, a guy can drive himself batty thinking about it too much
  19. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I've tried the Shinko 230 on my suzuki. The worked well. I've since installed them on my XJ. I can't complain one bit about them.
    Handle as well as the Challengers they replaced. And it looks like I may get more milage as well per tire..
    Just my $0.02,
  20. Stormin
    Stormin Member
    Poughkeepsie, NY
    Great. Thanks guys.
    Now, any suggestions on snow tires ?
    yep its snowing Again.
    Guess it's good the bikes not quite ready.
  21. hogfiddles
    I just came in from sledding.... If you can't beat it, enjoy it!!
  22. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Dave, you look like the cat that got the cream! I'm stuck right in the middle. Snows no good for anything, and the roads are still crap! I did have ice all over my car's wind shield after work last night though, so i got to scrape that. What fun.
