Kerker exaust, carb setting?
Discussion in 'XJ Modifications' started by snapper33, Oct 17, 2010.
  1. snapper33
    snapper33 Member
    United States
    Thank you up-front for any assistance.
    1982 550 Seca
    6,070 miles
    I have a brand new NOS Kerker 4:1 exhaust. What carb setting works, it seems a little cold-blooded now.
  2. bigfitz52
    Try backing out all 4 mixture screws about 1/8 turn, and then read the plugs.
    6K miles? Did it get its initial valve check at 3000?
  3. snapper33
    snapper33 Member
    United States
    Thank you! I'll try the carb adjustment.
    I'm not sure about the valve check. I just purchased it and the PO put the Kerker on. I better get that done too I guess.
  4. streetbrawler750
    streetbrawler750 Member
    Minnesota
    If it hesitates when you give it throttle and has a spot under acceleration where it should be going faster than it is try shimming the needles. Also you will probably need to up the main a couple, depending. Do a search on here and there is a lot of info on jetting (some useful... :roll: ) and welcome to the site. :lol:
  5. snapper33
    snapper33 Member
    United States
    Thanks streetbrawler.
    I wonder if I should put a different exhaust on that doesn't require other adjustments?
    Any opinion on that?
  6. streetbrawler750
    Minnesota
    Depends on you, if you don't want to mess with anything you could go back to stock. I wouldn't because 4-1 sounds awesome in my opinion.
  7. iwingameover
    iwingameover Active Member
    Everything requires adjustments. Some big some small.
    Where are you located? Someone may be close by to help.
  8. snapper33
    snapper33 Member
    United States
    I'm in Universal City, Texas, just NE of San Antonio. I've actually put an ad in Craigslist asking for a Yamaha mechanic to come and help. I'm a pretty good MC mechanic, but my other bikes are RDs. 4-strokes are new to me. I'll learn as I go.
    I do love the sound of the Kerker and it's a spanking new NOS pipe, 27 years old....crazy!
  9. iwingameover
    To start with are your carbs completely clean? You can't tune properly with dirty carbs. Also check the valves. Both should be easy jobs for anyone with mechanical experiance. Plenty of write ups here.
  10. snapper33
    snapper33 Member
    United States
    I will be cleaning the carbs very well. It seems a little daunting cracking the stack of carbs and cleaning them. I do not know where to get rebuild kits yet, but hopefully I'll figure that out.
    I have an old aircooled Porsche 911 and I adjust my own valves, pull the engine for clutch work etcetera and work on my 2-stroke RDs and GT so I guess I can tackle this one. I actually bought it to ride and learn 4-strokes...went with a 4-cyl, 'bout as crazy as starting on a CBX, but I'm in the fire now.
  11. Cmccully04
    Cmccully04 Member
    State College, PA
    everything you will need for the rebuild you can get from the local parts guy Len (chacal) here on the forums. go to the top of the page and click the engine, XJ4ever. you can browse his online catalog or just PM him and tell him what ya need and he will shoot you the info you requested. he is magnificant!!!!!
    *chris
  12. Orange-n-Black
    Memphis Area
    Welcome to the site and welcome to the fun! :lol:
