Key!
Discussion in 'XJ Technical Chat' started by peewee, Apr 13, 2008.
  1. peewee
    peewee Member
    SE Wisconsin
    Anyone know off hand if Yamaha dealers can cut keys by VIN or the serial number of the ignition switch? Its an 81 so I'm doubting it but I cant call on a Sunday. Just seeing if anyone else has had it done...
  2. xyxj650
    xyxj650 Member
    Fergus Falls MN
    I don't know if they can do that but if your helmet lokc and ignition lock are the same you can take your helmet lock to a locksmith and they can take it apart and make a key that way. I took mine to the neighborhood locksmith and it only cost around 10 bucks.
  3. peewee
    peewee Member
    SE Wisconsin
    I already pulled the ignition out. Wasn't too bad.
    If it's cheap I guess I'll have a locksmith do it. Just thought it would be more at a locksmith then the dealer.
  4. xyxj650
    xyxj650 Member
    Fergus Falls MN
    the helmet lock may be easier for them to take apart and cheaper to do. I don't know what is involved in taking apart the ignition to make the key. That is why I asked if you have the same key for the helmet lock.
  5. peewee
    peewee Member
    SE Wisconsin
    Oh. I didn't know they had to take it apart. I suppose I'll pull that too. They were the same key.
  6. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    I went to a lockshop to have one cut for the 80 Maxim by code but no code on the ignition. Turned out there was glass in it and it had to be dis-assembled anyway. Then they cut me 2 keys for $35. The Local Yamaha Dealer said they couldn't do it...
  7. Nick
    Nick Member
    Vernon, BC Canada
    Our bikes have a key code decal on the bottom of the ignition that can be used to cut the key at a locksmith not the dealer! At least our dealer can't cut keys here.
  8. peewee
    peewee Member
    SE Wisconsin
    Yeah mine still has the sticker on it. Guess I'll call around tomorrow, because I need to get out and ride!
  9. chacal
    Peewee, yes, with that key code SOME locksmith who have the older lock depth charts can de-code the number and cut a proper key. Other locksmiths can't. I would try to find the OLDEST locksmith in your area as they are most likely to have access to the older info.
    And write that key code down somewhere where it will last forever!
    Oh, and here's the bummer part: I've noticed on a couple of ignition sets that I've had that sometimes---{{{cover your ears here}}}----that sometimes the code engraved into the original key and the code on the ignition sticker don't always match quite exactly.......... :cry:
  10. Kenbo
    Kenbo Member
    Central Scotland
    Good call chacal about noting the code somewhere safe.
    My project bike cams keyless and the code on the ignition barrel was incompleate. Local dealer could have sent it off for me and got a key made but it was cheeper for me just to buy a new ignition which came with two keys. So new can still be got.
  11. peewee
    peewee Member
    SE Wisconsin
    Thanks guys. Found a guy in town who has been doing it forever and he cut the key for 18 bucks. I'm happy!
    Now just waiting for my batt to charge... But she fired up first crank with a jump. Surprising since it sat for over a month in the rain, snow, etc!
  12. Nick
    Nick Member
    Vernon, BC Canada
    Hope you got more then one key, in case the new one gets misplaced and you have to go thru this all over again!!!!
