Keys for 82 XJ550 Maxim
Discussion in 'XJ Technical Chat' started by TorontoXJ, Jun 12, 2015.
  1. TorontoXJ
    TorontoXJ New Member
    Toronto, Canada
    The bike I bought came with only 1 key so I'd like to get another couple made up.
    I heard you can order blanks on ebay and then get them cut locally.
    Does anyone know how to tell which key to order? I've attached a pic of the key and see a code on it, maybe that's it?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Take your key to a locksmith and have him cut as many keys as you want. Support your local business!
    Stumplifter likes this.
  3. mwhite74
    mwhite74 Member
    Damn, do you do hand modelling? :p
    I had some cut for mine at the local locksmith. Unless you want to get one cut from OEM Yamaha blanks they should have lots of 'common stock' to make a copy from.
  4. XJ550H
    the f is your style key the rest of the numbers are how the key is cut write them down. the key number is also on the bottom of your ignition switch.
    http://www.yamahakeys.com/login.php
