Keyster Carb Kit XJ650 Maxim
Discussion in 'XJ Technical Chat' started by eric.jones, Jun 14, 2008.
  1. eric.jones
    eric.jones New Member
    Phoenix, Arizona
    I've heard some fairly unflatering remarks regarding the K&L carb kits... I wonder if anyone has experience with the Keyster Carb kits found on wwww.siriusconinc.com I'm looking to rebuild shortly and need to JUMP
  2. Rat800
    Rat800 New Member
    Uk
    UK OWNERS DO NOT BUY KEYSTER 4KO KITS!!!!!!!!THESE KITS ARE OUT OF SPEC!!!!!!ALL JETS, NEEDLE JET & NEEDLE ARE 11N SPEC,I HAVE HAD NO RESPONSE FROM NRP CARBS WHO SOLD ME THE KIT,SO I WOULD NOT BE RECOMMENDING THEM EITHER. IF YOU BUY KEYSTER CHECK THE KIT SPEC AGAINST THE CARB SPEC FOR YOUR BIKE BEFORE YOU BUY.QUALITY OK,JUST NOT IN SPEC.
  3. mlew
    mlew Well-Known Member
    Apex, NC
    I agree, if you just need bowl gaskets and needle/seats they are good. Don't bother using any of the jets in the kit, they are the wrong size and you will be taking the carbs apart again if you use them.
