Larger brake disks
Discussion in 'XJ Technical Chat' started by Shaynus, Jan 5, 2015.
  1. Shaynus
    Shaynus Member
    Mandurah, Western Austalia
    Hi everyone.
    Does anyone know of a larger diameter brake disk (288 mm) that will fit the front wheel of my '84 XJ750?
    Cheers,
    Shaynus
  2. Polock
    why?
  3. Shaynus
    Shaynus Member
    Oops, typo. Should be 298mm diameter.
    Trying to match up my original front wheel with a set of blue spot calipers on FZR600 (YZF600? I forget!)
  4. KDub
    KDub Member
    Burnley, NW UK
    What bike? Because if it's one with the italic wheels then the YZF600 (Euro spec Thundercat) disc bolts right in, as does the earlier FZR600 and Euro spec FZR600R (same as '95 and '96 US spec YZF600). You may need spacers though. I tried this with my '82 XJ650 Maxim and the calipers fouled the wheel big time, but I was using calipers and forks from a Euro spec FZR600R, not sure if the bluespots are smaller.
  5. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    I put the YZF forks on mine with blue spot calipers, Pro Lite rotors and a master cylinder from the Kaw 636.
  6. Shaynus
    Shaynus Member
    What model bike is that Thrasher?
    What rear wheel are you using?
    I'm planning to use my original front wheel to keep the bike visually balanced as the more modern front wheel is larger than my original rear. Are there any straight forward swaps to put a larger wheel / tyre on the rear of a '84 XJ750 (factory 'special' that is a 900 frame with a 750 engine?
  7. Thrasher
    Thrasher Member
    It is/was a 1981 Seca XJ550 RH. The rear wheel is from a Suzuki 600 Katana. sat3.jpg
  8. Shaynus
    Shaynus Member
    That's cheating - you have a chain drive!
    Looks like you have a great bike there.
  9. Thrasher
    Thrasher Member
    Thanks.
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    And the swinging arm ? Looks great .. Still standard seca engine ? Love the exhaust too..
    Cheers
    James
  11. Thrasher
    Thrasher Member
    The swinger is from a 1988 FZ600. I welded the shock mounts to do away with the mono shock.
    FZ600 motor and a old school Yosh with comp baffle.
  12. hogfiddles
    He's not cheating........the 550's only came as a chain-drive bike.
  13. Kickaha
    New Zealand
    Any mods to fit it at the front swingarm pivot??
    What diameter are the forks?
  14. Thrasher
    Thrasher Member
    Not really. You will need to put some thin washers as shims under the bearing cup to take up what little slack there will be.
    The tough will be to fabricate and weld the shock mount brackets on.
    The forks are 41mm and are from the FZR600 or the YZF600. You will want to use the whole front end and may need to shorten the pivot shaft from the bottom.
  15. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    that is a bad ass looking motorcycle
  16. Thrasher
    Thrasher Member
    Thanks.
  17. Shaynus
    Shaynus Member
    Does anyone know of a database of OD, ID, PCD & offset for brake disks?
  18. Kickaha
    New Zealand
    Thanks, think I will look for a set for my 550
  19. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1. Why? Although Thrasher's set up is slick tho. Real nice.
    Gary H.
  20. Shaynus
    Shaynus Member
    As I posted previously to the question 'why?':
    "I'm planning to use my original front wheel to keep the bike visually balanced as the more modern front wheel is larger than my original rear. Are there any straight forward swaps to put a larger wheel / tyre on the rear of a '84 XJ750 (factory 'special' that is a 900 frame with a 750 engine?"
    I would prefer the rear wheel to be 'meatier' than the front.
    One of the original forks was slightly bent from the previous owner sliding it down the road and I got the FZR600 front end cheap.
    Bolted straight up...
  21. Shaynus
    Shaynus Member
    Result!
    FJR1300 front discs bolt straight up and have the desired 298mm diameter.
    Now onto wheel bearings / axle...
  22. Brandon Barnhart
    Brandon Barnhart New Member
    Indianapolis
    Anyone know if the FZ600 exhaust will work on my yics550 engine?
  23. hogfiddles
    It's not really a " factory 'special' ". It's a factory production model that was called the 1984 XJ750RL.
  24. k-moe
    And is coveted by at least me.
  25. Shaynus
    Shaynus Member
    You wouldn't be coveting this one, not the condition I got it in! :)
  26. k-moe
    I probably would. I like projects.
