LCD Screen
Discussion in 'XJ DIY How-To Instructions' started by CaptNemo, Jan 2, 2009.
  1. CaptNemo
    CaptNemo Member
    Reno
    Don't know if anyone will benefit from this but here goes.
    The LCD screen on my dash was getting to be unreadable due to the outer layer delaminating and falling apart. This is like a piece of tape that has the red and yellow rectangles that outline the warning items, (FUEL, BRAKE, HEADLIGHT etc.) that is on top of the glass unit. It was getting so I could barely see the words anymore so I decided to take it apart and see what I could do, I didn't think to take a before picture but I think you get the idea.
    I take it apart and remove the film and then reassemble, turn the key and there was nothing on the screen at all
    so I assume I screwed somthing up and repeat the whole process, not once but twice more. I'm sure I didn't break anything so I learn a little about liquid crystal displays on Wikipedia and learn that this outer film served another purpose:
    http://en.wikipedia.org/wiki/Liquid_crystal_display
    It was also one of two polarizing layers that allow us to see the display. To test this I grab an old pair of polarized glasses, put them on and lo and behold there is my display working perfectly.
    I found a website that sells polarizing film for avionics displays and ordered some. Now the interesting thing is that if you orient the film one way the display looks like we are all used too, but if you turn it 90 degress you get exactly the opposite look, black background with white letters. This is a purely optical effect with no influence on the electrical system at all. I chose to put it this way because it seems to go with the rest of the instruments much better. See what you think.
    It's very easy to read day or night but isn't as "in your face" as before. The information is there if I need it but not so distracting at night. The film I got was tinted for UV protection so it is a little muted, a clear film make pure white letters on the display.
    Of course I don't think anyone should ruin a good screen, but anyone who has one that is failing like mine was may be able to get it back, or anyone who would like to reduce the glare at night could try it too. I may switch mine back later, it's as simple to reverse as putting on a decal.
    Thanks for reading!
  2. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Great post. My guages are analog but there are a billion consumer devices with LCD displays.
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I used to do this with my calculators as a kid :) I was cool having a calc. that was black with white numbers lol
  4. bill
    bill Active Member
    Raleigh, NC
    Great post thanks for the tip!
  5. tomandjerry00
    tomandjerry00 Member
    Washington DC/Philadelphia
    That does fit the bike way better, thanks for the heads up!
  6. maximike
    maximike Member
    Portland, OR, USA
    I'd forgotten, I used to do this with whatever digital watch I had, a lot of them the crystal itself does this, if you take it out and flip it over you get a negative display, I'll have to do this to the atari computer on my bike, god knows I've taken it apart enough. I already had to make my own acrylic faceplate because I broke the glass one.
  7. CaptNemo
    CaptNemo Member
    Reno
    If flipping it over doen't work let me know, I bought a whole sheet of the polarizing film and have only used a little bit, would be happy to send you a slice if you want.
  8. Tim morris
    Tim morris Active Member Premium Member
    Hopatcong NJ 07843
    Do you still have any left I need to fix a bad dash lcd delamination Tim 201 230 6654 thanks texto me Ino thanks again
  9. XJ550H
    Tim morris likes this.
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Polarized filters are fun to play with. Learned about them in high school physics. Take two pairs of polarized sun glasses and overlap the lenses at right angles, then slowly turn one. You can "tune" the brightness. This is how variable light filtering windows and displays do it, except electronically.
  11. Tim morris
    Hopatcong NJ 07843
  12. Tim morris
    Hopatcong NJ 07843
    I could really use a slice if available thanks Tim morris.text details to 201 230 6654 thanks in advance
  13. XJ550H
    capt nemo has not been here for a while sept 2016 .the thread you replied to was posted 2010
  14. Tim morris
    Hopatcong NJ 07843
    Thanks i got some lcd film now just need to figure out how to change it ? Need videos has any one done video of lcd repairs yet ?
  15. Tim morris
    Hopatcong NJ 07843
  16. Tim morris
    Hopatcong NJ 07843
    Love it hopefully your still with us maybe you could do a video update of your repairs :) for us not so filmmillure,pun .
  17. Tim morris
    Hopatcong NJ 07843
    Any info.will help
  18. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Ouch
  19. Tim morris
    Hopatcong NJ 07843
    I am all over Internet on this one need to be engineer
  20. k-moe
    You remove the ATARI.
    You then disassemble the ATARI
    Atari disassemble
    The systems monitor needs to be removed (two JIS screws on the monitor housing)
    The monitor cover can then be removed, and the film changed. If the film doesn't appear to work, rotate it 90º
    CaptNemo and Tim morris like this.
