lead suplement
Discussion in 'XJ Technical Chat' started by ant797, Jun 20, 2016.
  1. ant797
    ant797 Member
    western australia
    the thaught just hit me today that these bikes might of been running on leaded petrol in the day should some kind of suplement be added valve saver stuff or something every tankfull or so?
    no in the 80's it was unleaded fuel
    became mandatory late 70's in US
  3. ant797
    ant797 Member
    western australia
    thanks also i was wondering if the inner diameter of the petcock to carby fuel hose matters to much i put a fuel injection hose on there quite thick outer diameter couldnt get the spring clip on it for the carby but the inner diameter looks cpl of mms smaller
  4. XJ550H
    i think fuel line is 6mm
    it could affect fuel flow at higher speeds due to higher demand
    1/4 inch fuel line is what you need 6mm = .23"
  5. ant797
    ant797 Member
    western australia
    all good then i looked at what i put on there n its 6mm
  6. ant797
    ant797 Member
    western australia
    cant quite get the spring clamp from the other fuel hose on there though on carby side reckon it be alright without one
  7. k-moe
    Should be. I run without one, but I also replace the fuel line every year. Since you used fuel line meant for a pressurized system you will need to get a larger clamp if you want to run one.
  8. ant797
    ant797 Member
    western australia
    cool i did get one on the petcock side realy hard to get anyother kind of clamp on the carby side without having to take it off the whole reason i had to replace the fuel line is because i tried fitting a fuel filter i short one but still theers just no room for it there is a filter connected to the petcock in the tank i hope thats enough
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I bought my XJ new in 1985. Dealer said unleaded gas no worries. He said do not run gas with alcohol in it as it will mess up the carburetors.
    Jetfixer likes this.
  10. k-moe
  11. k-moe
    Your dealer was half-right.
  12. cgutz
    SE South Dakota
    He may have overstated the gas with alcohol concern, and many today don't have the option but to run ethanol fuel.
    I will say I've never run more than a few tanks of gas/alcohol, and 30 years later not really any carb issues.
  13. ant797
    ant797 Member
    western australia
  14. XJ550H
    there is an arrow on the filter .think of the filter as an arrow and it points to the petcock
    you want the filter element having the maximum surface area in the upstream flow of gas
