Leaking Valve Cover "Half-Moons"
Discussion in 'XJ Technical Chat' started by Lou627, Jul 9, 2009.
  1. Lou627
    Lou627 Member
    Queens, NY
    I did a top end overhaul on my engine and tried to reuse the old (ripped) valve cover gasket. Of course, it leaked. So I put a new one in, and did it right. Now upon start up I get a fast leak/spray of oil from the half moons (on where day and night would meet on the moon :), or where the rubber meets the gasket). Should I be putting some sealant on this area? Or is it possibly the rubber doing its job and shooting oil because of something I may have messed up in the head? Remember the overhaul that was done...
    Thanks, Lou
  2. bill
    bill Active Member
    Raleigh, NC
    Lou did you change the donuts? They provide the pressure.
  3. Lou627
    Lou627 Member
    Queens, NY
    I don't have donuts on mine- I believe thats only on the yics models
  4. bill
    bill Active Member
    Raleigh, NC
    Ahh ok it was a thought
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    smear some RTV silicone (like ultra black) on the flat surface of the half-moon and let it cure... reinstall gasket and valve cover. It's possible that the half-moons may need to be replaced... Chacal prolly has them. If not, I've seen them on fleabay.
  6. Lou627
    Lou627 Member
    Queens, NY
    Cool, thinking the same. You had this problem too, eh? I was reading your post while searching the forums :)
  7. schmuckaholic
    California
    I'd like to know how you saw them as separate... those "half moons" are an integral part of the gasket.
  8. murray
    murray Member
    Sydney Australia
    Not with the pre YCIS model,it uses a paper gasket with seperate half-moon rubber inserts and allen head bolts around the peripheral of the rocker cover. Cheers, Murray
  9. bigfitz52
    Edzachary. You need to put a little bead of sealant along the line where the edge of the half-moons meet the paper gasket. Not LOTS, just enough to "squish" into the small gap between the edges of the "moons" and the paper gasket. This assumes the half-moons are still reasonably soft and pliable.
