Learning more about xj's Couple of questions.
Discussion in 'XJ Technical Chat' started by Robbietravels, Apr 30, 2011.
  1. Robbietravels
    Robbietravels New Member
    Redding Ca
    Today I had a chance to remove the cosmetic pieces on the 650 I was given to get a little better understand of the bike. Figured I would get ready for when I have some money to put into it. Also Got a chance to check the rear break pad delamination. Everything checks out. I'm hoping to take off the carbs this week and clean them out/get to know them better.
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    Dont believe the PO.
    Cyl 1 looks almost right. They should be a little brown-ish.
    The others don't look like they had fire! LOL
    WTH?
    If it where me I would open up the mix screws a little on the clean plugs. Get more gas on those.
    Between your thumb and first finger... look down in there for a large rubber square. That is the left "guys" home.
  3. Robbietravels
    Redding Ca
    Thanks Bill I don't see the rubber square might be missing. I see a bracket on the frame but no rubber square. I don't think these relays should just being bouncing around am I wrong?
  4. macros10
    macros10 Member
    Newport News, Virginia
    Zip tie them up for now :)
  5. bigfitz52
    Check with chacal for replacement relay "slings."
